Go to Post First of all, please remember that while we often focus on winning the Chairman's Award, that it is the effort to win that matters. No one "loses" RCA... if you've worked your butt off all year in the spirit of the award, then you've already won before you even get to the regional. - dtengineering [more]
Unread 03-01-2009, 21:49
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
Is <T02> necessary?
During the BETA testing I was very impressed with the wireless capabilities when paired with the LabVIEW front panel and looking forward to debugging my program and changing constants wirelessly at practice fields and in the pits during competition. Now I find that even though each team has a unique IP address you can't use wireless in the pits according to rule <T02>: "Radio control mode of ROBOT operation is not permitted areas anywhere outside the ARENA. ROBOTS must only be operated by tether when not within the ARENA."
Do multiple wireless networks interfere with each other? Couldn't we have our routers on wireless B while the arena ones use N if there is any interference?
Thanks!
Unread 03-01-2009, 22:44
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Re: Is <T02> necessary?
Eh, even though its probably "safe" to run robots wirelessly in the practice area, FIRST's probably just doing it "just in case". I don't know too much about wireless networks, but I know it can get iffy sometimes.
Though I totally don't have a problem connecting one long ethernet cable to the cRIO versus 15 serial cables strung together and falling apart.
-Tanner
Unread 03-01-2009, 23:45
s0crates s0crates is offline
s0crates is on a distinguished road
I can confidently say that yes, they do interfere with each other. 2 days ago we had a small local competition called BunnyBot, and my team and several others were using the new control system. We were tied for first place for matches won, so of course Murphy's Law strikes and our wrt router suddenly stopped functioning as we began the match. 30 min and 2 forfeited matches later, we had fixed it - for some reason it had decided to stop recognizing its assigned ip; we could not communicate with it. We ended up resetting it and configuring it from scratch. Later in the competition, our wga acted up and refused to connect to our wrt. We had previously tested everything for hours at some senior center with floor space we could borrow, and nothing ever acted up. The only difference between the testing and competing in that competition were the wireless networks being used simultaneously by other teams.
I can totally understand why first is banning wireless comm - with hundreds of teams testing/uploading in the same confined area, there would presumably be a lot more problems. Now that I think of it, (correct me if I'm mistaken) there are only ~22 channels in the 5Gh band required by first, so it appears to be impossible for that many wireless networks to coexist in the same area.
-Jonathan
Unread 04-01-2009, 01:02
During the NI training, there was discussion of the possibility that wireless robot operation might be permitted on practice fields. They'd most likely be restricted to the lower frequency band, with the higher one reserved for the competition field(s).
Robots not on a field would still be required to use tethers. I imagine that teams will be told to leave their wireless routers at home.
Unread 05-01-2009, 01:17
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
-Tanner
Just make sure to keep an eye on the cable, ethernet isn't exactly the most robust.
Or have spares since it's pretty cheap/free from your school.
Necessary Additions to "Starter Kit"? Katie Reynolds FIRST Tech Challenge 18 07-05-2006 15:27
Is defense necessary in practice rounds? pklevann Regional Competitions 17 15-03-2006 23:30
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
Are 100k Ohm pots necessary? MikeDubreuil Electrical 23 18-02-2005 09:30
calculating necessary ratio/pitch archiver 2001 2 23-06-2002 23:49
