Go to Post After each match the pit crew gathers up the parts from the field and finds a new and interesting way to assemble them. - tsaksa [more]
Unread 04-01-2009, 18:45
Lodyev Lodyev is offline
AKA: Dylan Adams
FRC #0422 (Mech Tech Dragons)
Lodyev is an unknown quantity at this point
Send a message via AIM to Lodyev Send a message via MSN to Lodyev Send a message via Yahoo to Lodyev
Re: Robots design?
Thinking outside of the box for this one wasn't a problem for us.
Building outside of it, well, that should be interesting...
Unread 04-01-2009, 18:48
excel2474's Avatar
excel2474 excel2474 is offline
AKA: Aaron Stewart
FRC #2474 (Excel)
excel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the roughexcel2474 is a jewel in the rough
Re: Robots design?
Originally Posted by Lesman View Post
I can't think of a way to shoot the balls. The most effective way to shoot in Aim High was feeding a ball through 2 pairs of spinning wheels but with these orbit balls I see a number of problems. It would be difficult to apply pressure, as they deform (and break) easily. Furthermore they do not have a uniform surface, to shots will be inconsistent. And, the fabric covering will decrease traction (especially compared to the rubbery foam in the nerf balls). I really can't imagine an effective shooter based on a softball pitcher model.The best I can think of is a catapult style shooter that I remember one team had in 2006.
I think you could still use a softball pitcher design, but yeah I think you are right about accuracy. But like Dean said, there will be some luck involved. I think that as long as you shoot enough balls in the general vicinity of your target, then luck might be on your side.
"Find some thing you like to do and EXCEL at it with dilligence."
University of Notre Dame- Mechanical Engineering.
Unread 04-01-2009, 18:53
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
Re: Robots design?
Luck is going to be a big factor this year, with the slipperiness of the ball and its poor durability any shooter is going to shoot every ball with a different velocity. Although if a team finds out how to successfully shoot a ball with accuracy, then they have made one heck of a bot.
'08, '09, '10
4 Years | 14 Competitions | 194 Matches | 119 Wins | 77 Losses | 2 Silver | 1 Gold
Unread 04-01-2009, 19:07
Re: Robots design?
We predict to see many resurrections of 06 bots + 02 bots. And a little hint of 05 thrown in there.
Unread 05-01-2009, 00:47
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
Re: Robots design?
people are forgetting about using the same strategy that some teams used in 2004
a: get the balls
b: dump them off to the HP
c: let the HP do his/her job and shoot em in
seems similar to 04 doesn't it?
(06 was pretty much the same thing, i could see a catapult system or a softball pitcher type shooter coming into play). What people don't realize is this, in 06 you were shooting at a still target, some teams could move in any direction and still score because of their cams and programming, but this year, thats a whole lot harder, because these targets are moving as well, that doesn't sound as hard as it is, but think about it this way
it takes a ball say .5 seconds to get ot the goal. because the goal is not fixed, the goal can move an ANY direction between that period, you will need to shoot and program accordingly... THIS is where luck comes into play,
(well, maybe not luck, but more of a mental game.)
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
Unread 05-01-2009, 02:04
Zach Purser's Avatar
Zach Purser Zach Purser is offline
AKA: Gumby
FRC #0435 (Robodogs)
Zach Purser is a jewel in the roughZach Purser is a jewel in the roughZach Purser is a jewel in the rough
Send a message via AIM to Zach Purser
Re: Robots design?
We're not going to be able the reuse our flywheel design from the Aim High bot. That thing would rip these balls to shreds, and I can't imagine how hard it would be to turn on this floor once the flywheel was up to speed.
Dave Lavery uses search before he posts, and you should too.
Unread 05-01-2009, 02:17
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
Re: Robots design?
I see a lot of different parts of old designs, especially 2006 (i've only been here since 05) coming together to be a formidable bot.
Young students design robots Carol General Forum 4 27-08-2008 21:01
Robots: Behind the Design Who is submitting? Wayne C. General Forum 33 23-04-2007 19:14
pic: FIRST Robots: Behind the Design (Cover) Vince Extra Discussion 25 02-04-2007 18:56
Are FIRST robots actually robots? EHaskins General Forum 39 14-12-2006 21:40
Students design robots, beneficial technology Billfred FIRST In the News... 0 07-02-2005 01:32
