Go to Post Building a 'bot is kinda like washing your hair, but instead of "rinse, lather, repeat"... you should "engineer, test, repeat". - Andy Baker [more]
Unread 05-01-2009, 02:50
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: Requesting Physists Help With Friction
As I understand it this years game should behave close to the ideal model of friction we are all familiar with. Both the floor (with the exception of the carpet) and the wheels are quite hard so the ideal model should be pretty accurate.
Between the soft rubber traction wheels and their patterned tread and the carpet both surfaces are fairly soft and have surfaces that can "grip" each other and not directly slide across each other. This is the source of the non-idealities that draw surface area into play. An extreme example of these "grip" interactions would be velcro.
Requesting Parts from Igus neoshaakti General Forum 4 27-01-2008 20:08
Requesting T-shirts From Teams All Around Kmo General Forum 13 18-12-2007 21:40
Requesting 2006 default code CyDrive Programming 11 03-05-2007 01:55
Requesting Inventor Files Dylan Gramlich Inventor 3 05-11-2006 00:56
LINUX Users: Requesting beta testers jdong Programming 35 20-03-2005 13:28
