Go to Post ...instead of question marks swirling my mind I got triangles, circles and squares... - Dorienne [more]
Unread 05-01-2009, 10:05
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Re: Defensive Strategies
Originally Posted by IndySam View Post
please quote the rule where this came from?
It's not written in the rule book...but it is assumed though different rules.
<G07> B. If a TRAILER tips over, the points SCORED for that TRAILER at the time it was tipped will be preserved for the remainder of the MATCH.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 05-01-2009, 10:22
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
....and if you don't tip it over and just remove balls?
Unread 05-01-2009, 10:32
Racer26 Racer26 is offline
By the same token, whats to stop you from building a <28x38x60 robot, and building a descoring mech on it and descore from your alliance partners trailers?
Unread 05-01-2009, 10:41
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Originally Posted by 1075guy View Post
I'm with IndySam, please quote such a rule. I have read the manual many times and seen no such indication that descoring by any means other than tipping is invalid.
Same here. The real question is whether this would be considered illegal "outside the bumper zone contact". That's where I see the GDC most likely to rule it out, particularly using <G32> parts E and F.
On the other hand:
Originally Posted by Game Manual, Section 6.1
The ARENA includes all elements of the game infrastructure that are required to play Lunacy: the CRATER, the ALLIANCE BASES, the OUTPOSTS, the FUELING STATIONS, the PAYLOAD TRAILERS...
Originally Posted by Game Manual, Section 7.3.5.2, <G29>
Arena Interaction –ROBOTS may push or react against any elements of the ARENA, provided there is no damage or disruption of the ARENA elements. With the exception of a ROBOT towing a TRAILER, ROBOTS may not grab, grasp, grapple, or attach to any ARENA structure.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 05-01-2009, 10:48
IMO, <G29> doesn't say anything about this. You're not grabbing, grasping, or grappling the TRAILER (an ARENA element), you're reaching into it, which is not mentioned, and therefore just fine.
EDIT: also, the game pieces themselves are not considered ARENA elements, and therefore grabbing, grasping, or grappling those is just fine.
Unread 05-01-2009, 10:57
KingBK's Avatar
KingBK KingBK is offline
FRC #1279 (Cold Fusion)
KingBK is an unknown quantity at this point
I really don't see a way to stop the other team from scoring on you. You could be able to put a lid on your trailer if you still fit in the dimensions but that is all your robot would really be able to do. I really think the best defense is going to be a good offense. Controlling the balls and making sure that you make them in the other alliances trailer before they make them in yours.
2009: Washington DC Regional Finalist (w/ 118 and 538)
2008: Bayou Regional Quarter-Finalists (w/ 499 and 945)
2008: NJ Regional Semi-Finalists (w/ 694 and 2016)
2006: NJ Regional Champions (w/ 103 and 25)
Unread 05-01-2009, 13:30
BigWhiteYeti's Avatar
BigWhiteYeti BigWhiteYeti is offline
FIRST class flier
AKA: Patrick M.
FRC #0857 (Superior Roboworks)
Team Role: Driver
BigWhiteYeti has a spectacular aura aboutBigWhiteYeti has a spectacular aura aboutBigWhiteYeti has a spectacular aura about
What if you just backed yourself into a corner of the arena and used your robot to block your goal? That could be useful end-game to prevent being supercelled by the other alliance.
-you're fired
Unread 05-01-2009, 13:32
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
not a bad idea but there is no real corner.
Unread 05-01-2009, 14:07
Petey's Avatar
Petey Petey is offline
Strategy &amp; Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
Depends on how good the human players were. 1073 won a playoff match in 2004 when the human player threw a playground ball into the goal from clear across the field at the last second.
But I agree, this is not a bad endgame strategy if you have no other defensive options (i.e. no lid, etc).
e: you do have to keep in mind that there is a red payload specialist on the side of the field and vice versa...there is no location for the robot to be that is more than 20 feet away from a human player...
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 05-01-2009, 14:37
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Just like 2006, having an alliance smart enough to know when NOT to chuck balls onto the field, missing their targets and providing the opposition more "ammo" in a fruitless, aggravating display of dumb is one of the better defensive strategies you can employ. Yeah, it might look cool to the crowd, but strategically, it's lame.
Deny the opposing alliance as much scoring "ammo" as you can. Conserve your ammo until the opportune time to unload it for maximum gain, or there's so little time left, the opposing alliance cannot "steal" it.
Unread 05-01-2009, 15:50
Petey's Avatar
AKA: Chris Peterson
What makes you say that?
Bio:
Unread 05-01-2009, 16:51
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
Originally Posted by R3V34L View Post
Keep in mind that Balls removed from your trailer still count against you, and if there are more balls in the trailer, less can be put in. If you remove balls, you have to balance that with the possibility that you can now have more points scored against you.
I would personally say that the fact that a "moon rock" is put in at the beginning is a great advantage for the end of the match when there is less room for a "super cell".
as of now, and i hope moving forward, that is inncorrect information, unless you can show a rule that spicificly states this situation
your comparing apples to oranges. totally different situations.
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
Unread 05-01-2009, 23:58
Bigflip2073's Avatar
Bigflip2073 Bigflip2073 is offline
&quot;Chyeah&quot;
AKA: Shane
FRC #2073 (EagleFarce)
Team Role: Electrical
Bigflip2073 is an unknown quantity at this point
I was thinking about this for a while
how about using air cannons to deflect cells?
How much would it take to actually have an effecton an incoming cell?
Most likely there wouldnt be enough pressure and volume for there to have an effect on an orbitball.
however i dont think it has been tried
We'll get there.....
Eventually xD
Unread 06-01-2009, 00:27
R3V34L R3V34L is offline
FRC #0948
R3V34L is an unknown quantity at this point
Apologies for the incorrect information, however if you are allowed to descore, then, I would assume descoring from allies is also allowed. If from yourself, then why not your teammates? This would a low a single robot on you team to be designated a "descorer" perhaps with a conveyor-hook settup to simply go up to allies and remove balls through the grates of their trailers. This seems to be against the spirit of the competition, leading to my previous point.
I still believe that it is not a good idea however, as I mentioned before, one moon rock in at the beginning means less room for a super cell to be tossed in during the last 20 seconds.
Unread 06-01-2009, 00:51
darkChozo darkChozo is offline
Some guy
darkChozo is an unknown quantity at this point
SCORED: A GAME PIECE is SCORED when it is fully supported by the TRAILER or other GAME PIECES that have been SCORED.
Technically speaking, from this definition, you could make it so it was impossible to score without getting a cell stuck on one of the outer bars by placing some sort of blocking mechanism at the bottom of your trailer. Because any cells going into the trailer are going to hit the bottom, placing something there will mean that they are supported partially by the robot, and thus are not scored. In turn, any cells stacked on top of them wouldn't be counted, as they are being supported by something other than the trailer and scored cells.
That being said, the GDC seems to be severely limiting what the robot can do outside of its boundaries, and it seems to me that any plausible method of descoring or blocking will probably be made pretty explicitly illegal when the Q&A. It would make sense, considering that most of the ways of blocking and descoring would be reasonably quick and easy, and would mean that a trailer is essential closed to scoring, thus providing an immense advantage and a more boring game.
defensive strategies Armando Rules/Strategy 74 14-04-2008 12:52
Defensive Strategies Goldeye Rules/Strategy 48 31-01-2006 19:16
YMTC: Defensive Strategies Matt Reiland You Make The Call 28 15-03-2005 15:11
Human player strategies? archiver 2001 6 24-06-2002 00:35
Best Strategies Rick Gibbs Regional Competitions 15 12-03-2002 09:23
