Go to Post Duh! Sometimes the simplest answers are the best ones! - dlavery [more]
Unread 24-06-2002, 00:21
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Joe Johnson Please Read....
Posted by Ryan at 2/6/2001 12:13 PM EST
Student on team #30, Fury, from High Technology High School and CelWave.
In Reply to: Joe Johnson Please Read....
Posted by Brian on 2/6/2001 7:33 AM EST:
: Joe,
: Every year my team has produced a drivetrain that has had a problem, the problem is that when we are driving(not that long of a period) maybe 5 minutes oneof the motors cut out and like if you wiggle the joystick it will come back. :
Hey,
My team has experienced the same problem, assuming you are using the BOSCH drill motors for your drive system. Two major faults with using these motors lies in how they are supposed to be layed out within the drill and how you lay them out on the robot. The first problem, is that although the motors appear to be "in" and attached to one another, if one side should slide out it causes the motor to disengage from the gear housing. My team uses 1/8" lexan as spacers underneath the motor to keep it inline. A second problem is the high/low shifter on the gear housing. When operating for over about 2 minutes it moves enough to slip in between the high/low gear. It is then unable to move and the motor spins but nothing else does. For this my team either uses a zip tie to hold it in one gear, or we use this year secret weapon... Hope this helps.
-Rc
[IMG] code is Off
Where is Joe Johnson? JVN Chit-Chat 6 11-01-2003 21:24
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
This one is for Joe Johnson archiver 2000 2 23-06-2002 23:32
? for Joe Johnson archiver 2000 1 23-06-2002 23:09
Hey Joe Johnson! archiver 2000 2 23-06-2002 23:07
