Go to Post Viva la geek! - Andy Baker [more]
Unread 05-01-2009, 12:09
Dan2081's Avatar
Dan2081 Dan2081 is offline
AKA: Dan
FRC #2081 (Icarus)
Dan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to beholdDan2081 is a splendid one to behold
Moving Hitch
An idea that my team has had was to have a moving hitch. The rules say that it must be rigidly fixed, however, would it be possible to have the hitch on some sort of rail, that could slide from one end of the robot to the other?? The regular setup would be in order, and it would be on the outer edge, just that the entire setup of the hitch could move??
Are there any points that would not allow this???
09 IRI #7seed and Semifinalists
09 BMR GM Industrial Design
08 BMR Engineering Inspiration
08 Archimedes #5 seed
07 BMR Rookie All-Star
Unread 05-01-2009, 12:18
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is online now
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Re: Moving Hitch
The only problem I see with this is that the 2 13/16 height of the hitch is within the bumper zone and bumpers must cover 2/3 of the perimeter. Other than that I see no rule saying the rigid fixation must be stationary. Get creative
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 05-01-2009, 12:23
Nate Laverdure's Avatar
FRC #2363
Re: Moving Hitch
The phrase I stressed in <R18> subsection B seems to prohibit this:
<R18> B.
The Trailer Hitch must be rigidly attached to a fixed location on the ROBOT, with the long dimension of the Trailer Hitch horizontal and the opening of the C-channel facing away from the ROBOT. The horizontal center line of the Trailer Hitch must be 2-13/16 inches above the floor.
This "fixed location" is defined in terms of relative position between GAME PIECE and ROBOT in Section 7, page 3:
A GAME PIECE shall be considered “captured” by a ROBOT if, as the ROBOT moves or changes orientation (e.g. backs up or spins in place), the GAME PIECE remains in approximately the same position relative to the ROBOT.
While a GAME PIECE is not the same as a TRAILER, I believe that the definition of "fixed location" is the same for both. However, this may be a question you should ask the Q&A service, once it becomes available.
Unread 06-01-2009, 16:01
timmmoore timmmoore is offline
FRC #1899
timmmoore is on a distinguished road
Re: Moving Hitch
You could argue that the definition of fixed location that you quote is when the robot is in playing configuration. If you assume the fixed location of the trailer hitch in R18 is in starting configuration, then I dont see why you can't change the "fixed location" between the 2 configurations.
An extreme example would be to start the robot standing on its front. it is very tall, wide and short. The trailer is hitched to the back of the robot in this config. When the robot starts it falls back over the top of the trailer with material expanding out to cover the trailer, which is now in the middle of the robot. What was the top of the robot in starting config is the back in playing config. Note this is an extreme example that I haven't worked out whether the sizes actually work or not.
Unread 06-01-2009, 20:22
Re: Moving Hitch
Originally Posted by timmmoore View Post
...I dont see why you can't change the "fixed location" between the 2 configurations.
Changing a "fixed location" sounds like a contradiction to me.
Unread 06-01-2009, 20:24
Hastypickle's Avatar
Hastypickle Hastypickle is offline
AKA: Nicholas
FRC #1703 (Rats)
Hastypickle is an unknown quantity at this point
Re: Moving Hitch
A moving hitch is now illegal because of the rule update.
In Rule <R18>, Part D “outer edge” has been changed to “BUMPER PERIMETER”. It
now reads as follows:
The Trailer Hitch must be located on the BUMPER PERIMETER of the
ROBOT structure such that it may easily connect with the tongue of the
TRAILER (attached to the TRAILER).
moving avatar CCCP Chit-Chat 6 04-02-2008 09:26
Moving Backwards Xenozero General Forum 6 06-01-2008 21:00
Moving up or Moving on? Simon Strauss Team Organization 18 21-05-2006 21:38
FIRST moving to Indy? David Kelly Rumor Mill 66 09-09-2004 18:30
