Go to Post It's like FIRST saying "Well it was too hard, so we give up. Lets give the kids something easier to do." How is that supposed to inspire kids? - Mike [more]
Unread 05-01-2009, 03:46
koreabell koreabell is offline
Team 956 Safety Captain
FRC #0956 (Eagles)
koreabell is an unknown quantity at this point
compiling in windriver
i searched but i couldn't find answer to it yet, if there are some threads regarding my question already, please let me know
my question is that is there any way to find out an error in the code without downloading the code to cRio or using debugging tool(which requires connection with cRio)?
i tried to build with intentional error( missing semicolon and missing headerfile) and it worked, so i guess it's not compiling the code or detecting errors.
so i'm wondering if windriver workbench can detect code errors without connection with cRio, like other IDEs did before(command IDE to compile, if there are some errors, compile failure, if not, compile to download).
Unread 05-01-2009, 12:49
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: compiling in windriver
I had this problem and it was caused by me moving the workspace from the default. You need to make sure you used the default locations.
Program - C:\windriver
Workspace - C:\windriver\workspace
Unread 05-01-2009, 14:36
AKA: Brad
#0190 ( Gompei and the Herd)
You can find syntax errors in the program by compiling it. You don't need a cRIO to do that. Just right-click on the project in the "Project Explorer" window and select, "Build Project". You should see any errors in the "Problems" or "Build Console" tabs at the bottom of the screen.
Brad Miller
Robotics Resource Center
Unread 05-01-2009, 15:26
FRC #0956 (Eagles)
well, i did that bunch of times with intentional errors in the code but it'll still build/rebuild the project successfully with no errors.
i don't see any errors or warnings on "Problems" or "Build Console" tab
does anyone not get any errors or warnings other than me?
Unread 05-01-2009, 15:32
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
I could see that happening if you had multiple projects open and didn't know which was the active project. I would analyze the output window closely and make sure you are compiling the project you think you are. All else fails just right click on your project and choose close unrelated projects.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Windriver LAC McGurky C/C++ 12 25-02-2009 18:38
WindRiver C++ Specific Keywords kyungjin C/C++ 8 01-02-2009 12:42
how to install windriver!! mole Programming 4 30-12-2008 12:52
windriver projects nickmagus Programming 4 01-12-2008 23:29
