Re: Blocking your own trailer
in response to the robot width being the 38" direction - I believe this is totally legal but it does state in the rules that the trailer will be attached to the SHORT side of the robot. so, if the robot design had the wide sides in the front and back, then the trailer would be sliding along beside it on the left or right.
<R18> Quote:
Well what you could do is create a robot that is really small, then when you create the cover your robot will not go outside the limits since your robot is already tiny to begin with. Also one rule states that you need all balls able to be taken out of your trailer at the end of the match without powering your robot back up so if you were to make something, you would need to make it retractable at the end of the match.
im going to quote bills blog on this one:
"Good Morning Teams, I want to clarify the Game Design Committee’s intention on a few matters to save you time and resources: 1) De-scoring is not permitted (ie. You may not remove game pieces from a trailer) 2) Goal tending is not permitted (ie. You may not block access to a trailer) 3) Don’t spend time attempting to develop a vacuum car system like Jim Hall’s sucker Chaparral car. Even a slight suction over the base of the robot will damage the field surface and you don’t want to do that (See the 2009 FIRST Robotics Competition Manual section 7 rules G-29 & G-30)" which in essence says NO blocking the trailer, and that it will probably be specified directly in a team update. |
#7
what about a robot, full size with that fans tucked in against the top? of course i also mean under the height limit?
#8
If you haven't seen this from Bill's Blog today:
So in short, no, you cannot block your own trailer. |
#9
Blowing air isnt blocking as far as we have seen, people will still be able to score and it isnt technically physical blocking... being one to have seen Bill's Blog...
#10
If you ask this on the Q&A, I'm willing to bet that the GDC responds that this is against the intent of the rules, and is not legal. |
#11
I guess i will ask...
#12
I would consider blowing air a means of goal tending, and since goal tending is illegal blowing air would be too. EDIT: the quote didn't show, just look at Smurfgirl's post to see what i am talking about |
#13
If you made a 28"x28" robot then you could have 10" to cover the trailer without having to worry about the trailer touching your robot or the rule about fixing your trailer hitch in one position. This could work if you had no bumper on the back then there would be no backside barrier for the limit in terms of the rule that you cant extend past the bumper zone. If there is no bumper zone in the rear then you can extend out over the trailer.
Think about that |
#14
The BUMPER PERIMITER is closer to what you're talking about. However, it completely surrounds a robot at the BUMPER ZONE height, and no part of the robot may extend beyond it (with exceptions for the trailer hitch and the bumpers themselves, of course). Last edited by GaryVoshol : 08-01-2009 at 08:42. |
#15
i think there is a rule that the trailer has to be conected to the outer most point of the robot
| detecting your own alliance(C++) | nathanww | C/C++ | 17 | 11-01-2009 17:13 |
| Make your own CNC | whytheheckme | Technical Discussion | 8 | 25-07-2007 02:13 |
| Make Your Own Whiteboard! | buss | General Forum | 13 | 15-01-2007 17:58 |
| Goal blocking your corral? Not a problem anymore | Ricky Q. | Rules/Strategy | 15 | 04-04-2004 17:38 |
| Making your own gearbox? | ChaosMonkey | Motors | 15 | 25-05-2002 11:07 |
