Go to Post Now, everyone, say it with me: "It's just a TV show and FRC is just a robotics program. My life is a lot bigger than both of those things." Once you say this, I swear most of the arguments here would fade into oblivion. - itsjustjon [more]
  #31   Spotlight this post!
Unread 05-01-2009, 11:31
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: Crab Steering on Regolith
I totally agree. they just want you to use the "flat" part of the wheel.
Originally Posted by megaman_22201 View Post
i believe that crab drive would be allowed because rule R06 reffers to the "normal" orriantation as the wheels being flat on the ground. this only means that the wheels cant be angled to the floor, it has no constraints on how the wheels can be in oriantiation to the robot.
in short, rule R06 states that the wheels have to be perpendiculer with the floor, therefore crab drive would be possible.
  #32   Spotlight this post!
Unread 05-01-2009, 12:25
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Originally Posted by 1075guy View Post
To me, the INTENT of <R06> is to prevent teams from utilizing the spokes of the wheel as a traction surface. It is NOT (IMO) intended to stop teams from creatively USING these wheels, in, for instance, a big omniwheel made with these as the rollers, or other creative uses.
A big omniwheel would be redundant as they are already basically omniwheels. A mecanum (spelling?) wheel however...
Also I'm not sure a giant omni wheel made of these would work because then technically your wheels don't always have their axles parallel to the ground, but they do when they are in contact with the ground...Still questionable.
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
  #33   Spotlight this post!
Unread 05-01-2009, 14:57
Lesman's Avatar
Lesman Lesman is offline
FRC #1014 (Bad Robot)
Lesman will become famous soon enough
Actually, these wheels are anti-onmi wheels. The idea behind omnis is that they have a negligible transverse coefficient of friction (CoF) (due to the rollers) and a much higher inline CoF (usually due to the rubber material of the rollers). These wheels are the exact opposite, with an inline CoF on less than half of the transverse CoF. In fact, I doubt a standard configuration of omni wheels would move at all, with the exception of turning in place.
  #34   Spotlight this post!
Unread 09-01-2009, 16:35
omgapirate's Avatar
omgapirate omgapirate is offline
FRC #1676 (Pascack Pioneers)
Team Role: Electrical
omgapirate is an unknown quantity at this point
Thumbs down Re: Crab Steering on Regolith
I am not sure if this has been said but I believe that somewhere in the rules it states that the coefficient of friction doubles if the wheels are turned sideways
pic: steering edomus Extra Discussion 10 05-06-2005 11:12
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
What is crab steering?? Adam Y. Technical Discussion 18 30-12-2002 08:12
tank steering archiver 2000 10 23-06-2002 22:28
4 wheel steering/ Crab Huey_Da_X-cat Technical Discussion 3 11-02-2002 22:49
