Go to Post FIRST does not follow patterns. - Mike Soukup [more]
Unread 05-01-2009, 16:59
GregW11's Avatar
GregW11 GregW11 is offline
Mad-haired biker man
FRC #2261 (Casa MESA)
GregW11 is on a distinguished road
Send a message via AIM to GregW11 Send a message via MSN to GregW11
Re: 4WD Turning Difficulties
Hm... what if you had a six-wheel design (skid steer, it won't work so well for arcade style) in which the front and back wheels had motors but the center wheels didn't, and there were sensors in all the wheels. The center wheels would be the actual rotation of the wheels while the front and back would be what the motors are doing, and the controller would adjust the output of these motors based on the actual wheel rotation versus what the motors are trying to do. (if that made any sense at all) I'll try to explain in a diagram below:
| | <motors on these wheels sensor compares rpm to center wheels
| | <no motors on these wheels, sensor gets rpm for actual speed
| | <motors on these wheels, sensor compares rpm to center wheels
Controller will adjust actual output of the motors. It's not fully autonomous, since you're still controlling which direction it is supposed to be going and the speed desired.
If anyone wants me to I'll try and do a sort of block-diagram showing a general flow of possible commands.
IR Difficulties AmitCarmeli Programming 3 11-01-2008 20:49
Technical Difficulties muy dificil Programming 0 13-10-2005 11:25
Default Code Difficulties Drok00 Programming 3 02-02-2005 20:56
FIRST Technical Difficulties at Rutgers aka Scott White General Forum 10 27-03-2002 14:40
