Go to Post FIRST doesn't graduate you from HS ... your performance in class (your grades) do. - Franchesca [more]
Unread 03-01-2009, 23:58
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
pic: Size of tthe 2009 Goal
Unread 03-01-2009, 23:59
Re: pic: Size of tthe 2009 Goal
Most teams in our area found these for 10 bucks a pop, does anyone know if FIRST is getting some huge discount?
Also, it may just be me who didn't find it, but what is the height of the goal from the ground to the lowest beam and from the ground to the tallest beam? This would be really helpful.
Unread 04-01-2009, 00:54
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
I don't have a quote at the moment, but from my memory the lowest is 34 inches and highest is 42, there are drawings and diagrams under the arena section of the manual
Unread 04-01-2009, 03:47
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Do the balls actually wedge in between the central post and the pipes, or do they drop/fall right in?
Unread 04-01-2009, 09:47
RoboMom RoboMom is offline
people expediter on Team Kluge
AKA: Jenny Beatty, no relation
no team (they are all my teams)
RoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond repute
Thanks to our local NASA contact and kickoff coordinator, we had one of these goals already built at our kickoff yesterday.
My impressions from watching the teams play around with it - it is challenging to get the balls to fall/drop right in (and the goal was not moving at the time.) More of the balls were ending up hooking the pipes or bouncing out.
Co-Founder of NEMO (Non-Engineering Mentor Organization) www.firstnemo.org
Volunteer Director, STEMaction, Inc. www.stemaction.org
FIRST Senior Mentor: Nov. 2004 to June 2009: "Experience is that marvelous thing that enables you to recognize a mistake when you make it again"
This is How I Work: http://www.chiefdelphi.com/media/papers/2862
Unread 04-01-2009, 11:18
KingBK's Avatar
KingBK KingBK is offline
FRC #1279 (Cold Fusion)
KingBK is an unknown quantity at this point
Well even if they ball gets caught around the pipes it still counts as in. But my question is with the beam in the middle how hard is it to bank it of off that and keep it in or do the balls just bounce off?
2009: Washington DC Regional Finalist (w/ 118 and 538)
2008: Bayou Regional Quarter-Finalists (w/ 499 and 945)
2008: NJ Regional Semi-Finalists (w/ 694 and 2016)
2006: NJ Regional Champions (w/ 103 and 25)
Unread 04-01-2009, 11:53
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
i was wondering that to, does the orbit ball need to be i the hoop or can it be hooked on a hoop?
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 04-01-2009, 13:22
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Originally Posted by Game Manual, Section 7.2
SCORED: A GAME PIECE is SCORED when it is fully supported by the TRAILER or other GAME PIECES that have been SCORED.
The manual makes the answer clear.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 04-01-2009, 23:04
Elgin Clock's Avatar
FRC #0237 (Black Magic)
There is adequate space for a ball to drop right in fed only by gravity, (aka: not pushed in) provided there are no other balls in the way or the goal is broken.
The fit of the ball between the center pole & the outer pvc poles obviously depends on the size of a squished ball, but in a normal (non-broken ball) shape, it won't be a problem to drop in from above.
HOWEVER
, as Jenny mentioned, throwing the ball into the goal will be interesting with the poles being different sizes around the edge if you decide to bank it off the center pole. It's not difficult, you just need to find that sweet spot in relation to the arc you throw it, & where it will bounce against the outer poles to sink in the goal.
It reminds me of the carnival game where you have to arc a softball against an angled wall & drop it in a metal bin at the bottom if you know what I'm talking about.
Game Manual, Section 7.2 SCORED: A GAME PIECE is SCORED when it is fully supported by the TRAILER or other GAME PIECES that have been SCORED.
In 2002, a ball on the outer lip of the goal counted as scored. (Aka: A ball wedged in between the outer pvc & the bumper material - relating it to this year -
(It was EXTREMELY rare, but it did happen to us one single time that year & was actually a deciding point in the game in our favor)
I want to know if a ball sitting on the outside of the ring of pvc will count again this year since it is still supported by the trailer.
Sounds like a question for the Q&A just for clarification purposes.
Unread 04-01-2009, 23:21
Swerting's Avatar
Swerting Swerting is offline
King of the Geats
FRC #1523 (MARS)
Swerting is on a distinguished road
Well, with a nine inch diameter for the ball, and 10.5 inches between the inside diameter of the pvc poles and the center post, that leaves little room for error.
And for the prices, take those moderately bruised balls, haggle with the manager to get a discount, and glue the plastic together. Then you just have to ducktape the fabric and BAM! you get a semi-decent ball that you will likely have to deal with in the competition since I highly doubt that FIRST can afford brand new balls for every match.
P.S. Run-on sentences for the win! Pay attention in english class kiddies.
Six weeks is plenty of time to design and build a robot.
What do you mean that includes testing it?!?
I will forever see the first logo in my sleep.
Unread 05-01-2009, 17:09
web_master_dpep's Avatar
web_master_dpep web_master_dpep is offline
"What you do, is who you are"
AKA: Dustin Pepper
FRC #0066 (Flyers)
Team Role: Webmaster
web_master_dpep is an unknown quantity at this point
Send a message via AIM to web_master_dpep Send a message via Yahoo to web_master_dpep
The heights of the pipes vary linearly, from 34 inches off the floor in the back, to 42 inches off the floor in the front of the TRAILER. This arrangement allows the pipes to act as a flexible “backstop” for GAME PIECES that are thrown into the TRAILER.
This can be found under The Arena part of the manual.
GOOD LUCK!
ŴΣß ΜăşťΣΓ đÞΣÞÞ
Unread 06-01-2009, 21:38
1522_Kira's Avatar
1522_Kira 1522_Kira is offline
AKA: Kaitlin
FRC #1522 (Defenders of the Multiverse ( DOTM ))
1522_Kira is an unknown quantity at this point
Send a message via AIM to 1522_Kira Send a message via Yahoo to 1522_Kira
We too have gotten one from a kick off. We're just holding it fo the time being. Me along with some others have been messing around with it. I have found it to be very easy to bounce it off of the middle pole. That might just be an easy way for the way I throw, but I make it almost everytime I throw it. So using it is a great way to get the balls in.
Unread 07-01-2009, 09:01
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
Did you throw over a six and a half foot wall though or try and simulate that?
Unread 09-01-2009, 21:04
1522_Kira's Avatar
AKA: Kaitlin
We too have a whole corner of the feild, so yes. We also messed around with attaching the trailer to our prototype bot, drving that around while some body throws. It'll be interesting for sure.
pic: Swampy Goal Tytus Gerrish Extra Discussion 7 19-01-2006 12:29
pic: Side Goal Camera Wetzel Extra Discussion 5 14-01-2006 14:04
pic: 766 lifting a goal razor95kds Robot Showcase 2 22-02-2005 16:40
pic: SPIKE caps a goal CD47-Bot Extra Discussion 3 06-03-2004 10:03
pic: movable goal CD47-Bot Extra Discussion 1 27-01-2004 14:11
