Go to Post Robot gets bored during practice, wanted to listen to some podcasts. - Tom Bottiglieri [more]
Unread 05-01-2009, 17:33
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Green and pink painted robot (a good defence?)
Well lets assume a robot on the opposite alliance has made great use of the camera and has a game winning auto aim and fire algorithm.
Would painting the robot green and pink provide some sort of defensive advantage?
Unread 05-01-2009, 17:38
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: Green and pink painted robot (a good defence?)
Note R02 C
Items specifically PROHIBITED from use on the ROBOT include:
C.
Any devices or decorations specifically intended to jam or interfere with the remote sensing capabilities (including vision systems, acoustic range finders, sonars, infra-red proximity detectors, etc.) of another robot (i.e. changing ROBOT color to confuse opponent’s vision system)
Unread 05-01-2009, 17:40
Sean Raia's Avatar
Green and pink painted robot (Good defence?)
sorry to post twice, but i think this would get more responses here.
Would painting the robot green and pink provide some sort of defensive advantage? would it confuse the camera?
Unread 05-01-2009, 17:43
Alex Dinsmoor's Avatar
Alex Dinsmoor Alex Dinsmoor is offline
Are our seeding points over 9000?
FRC #0201 (FEDS)
Alex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant futureAlex Dinsmoor has a brilliant future
Send a message via AIM to Alex Dinsmoor
Re: Green and pink painted robot (Good defence?)
I thought of the exact same strategy, but the high cost ruled it out for me
Well it all depends on how the robot was programmed. There is a chance that it may interfere with the aiming system, but at the same time they may have angled their cameras not to look at targets as low as your robot.
And don't forget, it may interfere with your alliance also...
'08, '09, '10
4 Years | 14 Competitions | 194 Matches | 119 Wins | 77 Losses | 2 Silver | 1 Gold
Sean Raia's Avatar
It does not mention colors. the devices listed give unfair technical disturbance or blind out the camera completely. The green and pink paint is not going to interfere with the camera, it will simply confuse it.
Unread 05-01-2009, 17:44
I responded to your original and so I will repost here
See R02 part C
C.
Unread 05-01-2009, 17:45
Would it? Possibly/probably. In that case, <R02> comes into effect and you get penalized under <S04>.
Originally Posted by Section 8
<R02>
ROBOT parts shall not be made from hazardous materials, be unsafe, or cause an unsafe condition. Items specifically PROHIBITED from use on the ROBOT include:
C.
Any devices or decorations specifically intended to jam or interfere with the remote sensing capabilities (including vision systems, acoustic range finders, sonars, infra-red proximity detctors, etc.) of another robot (i.e. changing ROBOT color to confuse opponent’s vision system)
Originally Posted by Section 7
<S04> Permitted ROBOTS - Any ROBOT used during a MATCH must be in compliance with all Robot Rules (as defined in Chapter 8). Any ROBOT in violation of a Robot Rule will automatically be assigned a PENALTY and may receive a Yellow Card, depending on the severity of the infraction.
Unread 05-01-2009, 17:46
The last example i.e. changing the robots color is somewhat clear. In past years this has always been interpreted to mean you can not mount target lights or paint your robot in such a way so as to confuse your opponents vision systems.
Unread 05-01-2009, 17:47
Sean Raia's Avatar
Yea, there goes my idea, UNLESS you just had a random pole sticking up (not exceeding max height) that was the same collor pattern as your alliances, YEA THAT MIGHT WORK!
Edit: im going to clarify this with Q&A because this seems to be a legit defence strategy and im worried that they wouldnt allow it
Unread 05-01-2009, 17:48
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
I would consider a painted stick a device. Granted, its a very simple device, but it has a purpose and therefore is a device.
My opinion though.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
I would say that paint is a decoration, not to mention the specific example of color-changing robots. And confusing a camera would certainly interfere with its accuracy, which was probably the whole point of using a camera.
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Fred Sayre's Avatar
Fred Sayre Fred Sayre is offline
AKA: Fred Sayre
FRC #0488 (xbot)
Fred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant futureFred Sayre has a brilliant future
Send a message via AIM to Fred Sayre
Says right there in the text that was quoted
Unread 05-01-2009, 17:52
Sean Raia's Avatar
Exclamation Re: Green and pink painted robot (a good defence?)
Oh too bad. it would have been awsome.
Unread 05-01-2009, 17:54
Eric et al,
A robot employing such colorful marking(s) should not make it through inspection. However, (S04) would cover any team that reintroduced such color or which made it through inspection without notice.
Unread 05-01-2009, 17:56
I wonder how this will impact the traditional Pink and Green teams. Moe has been green for years, do they have to mute their color this year?
Finding green/pink flags ellisk C/C++ 24 06-02-2009 20:04
pic: Da Bears shaved and painted just for 11! aallen88 Extra Discussion 17 08-11-2006 21:10
Good Night, and Good Luck. Ken Leung Chit-Chat 2 25-10-2005 11:09
Concerns regarding the green paneling/green shirts Petey General Forum 127 15-01-2005 10:35
To Pink Thinkers and Raider Roboticists Kris Verdeyen Thanks and/or Congrats 1 03-05-2002 20:22
