Go to Post You can't stop trying to look for other ways to do things, or that really defeats the whole purpose of inovation. - AmoryG [more]
  #46   Spotlight this post!
Unread 05-01-2009, 17:43
Electrical Engineer
Rookie Year: 1995
Re: Hovercraft
Originally Posted by scirobotics View Post
it is illigal to genarate downforce with a fan
Would you mind quoting the specific rule?
Mike Betts
As easy as 355/113...
  #47   Spotlight this post!
Unread 05-01-2009, 18:14
OScubed's Avatar
OScubed OScubed is offline
Lee Drake, CEO, OS-Cubed Inc.
AKA: Lee Drake
FRC #1511 (Rolling Thunder)
Team Role: Parent
OScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond reputeOScubed has a reputation beyond repute
Send a message via ICQ to OScubed Send a message via AIM to OScubed Send a message via MSN to OScubed
Re: Hovercraft
It's pretty clear that anything that provides additional traction is ruled out by R06:
<R06>
ROBOTs must use ROVER WHEELS (as supplied in the 2009 Kit Of Parts and/or their equivalent as provided by the supplying vendor) to provide traction between the ROBOT and the ARENA. Any number of ROVER WHEELS may be used. The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). No other forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction) are permitted.
The surface tread of the ROVER WHEELS may not be modified except through normal wear-and-tear. Specifically, the addition of cleats, studs, carved treads, alterations to the wheel profile, high-traction surface treatments, adhesive coatings, abrasive materials, and/or other attachments are prohibited. The intent of this rule is that the ROVER WHEELS be used in as close to their “out of the box” condition as possible, to provide the intended low-friction dynamic performance during the game
Note the OR OTHER DEVICES INTENDED TO PROVIDE TRACTION.
Lee Drake, CEO, OS-Cubed, Inc.
Business Mentor - team 1511
Rochester, NY
Building optimal, stable, secure solutions to your business challenges.
  #48   Spotlight this post!
Unread 05-01-2009, 19:16
T3H_K3YM45T3R's Avatar
T3H_K3YM45T3R T3H_K3YM45T3R is offline
AKA: Christopher Robinson
FRC #1737 (Project X)
T3H_K3YM45T3R is an unknown quantity at this point
Re: Hovercraft
I don't think that a downward force would be "creating traction" but be closer to "increasing" traction, which I guess depending on how you look at it could "create" traction.
  #49   Spotlight this post!
Unread 05-01-2009, 22:42
minisimon's Avatar
minisimon minisimon is offline
AKA: Simon Helmore
FRC #0238
minisimon will become famous soon enoughminisimon will become famous soon enough
Re: Hovercraft
I have to agree with T3H_K3YM45T3R on this one. If you consider any device that creates a normal force to be a traction increasing device, then ballast isn't allowed (actually, anything with mass isn't allowed). This doesn't seem realistic.
  #50   Spotlight this post!
Unread 06-01-2009, 00:33
ScottX's Avatar
ScottX ScottX is offline
FRC #0047 (Chief Delphi)
ScottX is an unknown quantity at this point
Re: Hovercraft
haha! If u get that working post up a video! People are craving to see if it works..
SCHOOL ROCKS!
  #51   Spotlight this post!
Unread 06-01-2009, 09:16
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
Re: Hovercraft
In the late 1960's, Jim Hall designed a racing car, the Chaparral 2J, that used auxiliary fans to create suction. It greatyl increased traction, so much so that the rules were changed to make it illegal.
Here's a photo of it:
Others have made smaller versions:
This technique would certainly be possible on an FRC robot, but the question is: would it be legal?
We'll have to wait and see what FIRST says.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
  #52   Spotlight this post!
Unread 06-01-2009, 09:21
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
Re: Hovercraft
there is no way the compressor/motors will be able to keep the skirt inflated AND provide thrust, its just out of the question, another thing to remember is battery power...
"Measure once, cut twice... wait... what?"
"Two things needed to build a robot.. WD40 for the things that don't move but should, and Duct tape for the things that move but shouldn't"
  #53   Spotlight this post!
Unread 06-01-2009, 10:22
gregscott gregscott is offline
gregscott is an unknown quantity at this point
Re: Hovercraft
Originally Posted by bduddy View Post
F1 buffs will get this one.
EDIT: Hmm, where did the picture go? Err, anyway...
en.wikipedia.org/wiki/Brabham_BT46B
Actually, the first to use the fan concept was Jim Hall with his Chaparral 2J in 1970. Jim was a great innovator and most of the aerodynamic ideas used in racing today originate with him. His most successful from a winning standpoint was the 2E which used a moveable wing to provide downforce in corners but which could be leveled on the straights to provide minimal drag.
As usually happens, his ideas were proved so effective that they were outlawed after 1 or 2 seasons.
One of the things that happens in racing is that if you come up with a really brilliant idea, someone will try to ban it in the name of "level competition". As you write the rules tighter and tighter, there becomes less and less possibility for really great leaps of creativity...just think of NASCAR.
I worry that FIRST is going in that direction.
pic: Hovercraft cart ChristinaR Extra Discussion 41 09-04-2008 02:24
Hovercraft? jennpeeler Rules/Strategy 19 25-10-2006 19:46
Hovercraft edomus General Forum 24 02-06-2005 21:00
pic: Hovercraft edomus Extra Discussion 11 01-06-2005 11:55
