Go to Post Make other plans. No mass-produced food at an arena is ever going to be good. - sanddrag [more]
Unread 05-01-2009, 18:32
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
Motors not responding to joysticks
My main problem right now is that the motors are not responding to joysticks. The CRIO is updated and is on auto-start. There was a voltage problem with one of the ports, but they were moved and are now working. The readout on the driver station says that the voltage is 00.00. The battery is charged and the yellow lights on the speed controller do stay illuminated when I switch the driver station to enabled.
Does anyone known what could be wrong and how to fix it?
Unread 05-01-2009, 18:58
rrossbach rrossbach is offline
AKA: Ron R
FRC #2607 (RoboVikings)
rrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to beholdrrossbach is a splendid one to behold
Re: Motors not responding to joysticks
Are you using your own code or one of the frameworks unmodified?
Is the DS in Teleop mode?
When you move the joysticks do the speed controller lights change color?
Unread 05-01-2009, 19:17
AKA: Ryan Guinn
The code is frameworks unmodified.
It is in teleop mode.
The lights on the speed controller stay solid yellow, even when moving the joysticks.
Unread 05-01-2009, 19:51
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
To read battery voltage the a jumper has to used to place analog input 8 in "battery monitor" mode(instructions for doing this are in the analog breakout datasheet)
As for the joystick problem, you might want to check the connections between the SCs and digital sidecar, as well as plug your joysticks into a computer. Another thing to note is that the DS will only initialize joysticks if they're plugged in before it is turned on.
Get yer robot source code here!
Unread 06-01-2009, 12:38
FRC2338webteam's Avatar
FRC2338webteam FRC2338webteam is offline
FRC2338 Web Team
Team Role: Webmaster
FRC2338webteam is an unknown quantity at this point
We fixed this problem by updating the LabVIEW and cRIO with the new software. http://first.wpi.edu/FRC/frcupdates.html
Oswego FIRST Robotics Team 2338 - http://www.oswegofirst.org
Unread 06-01-2009, 18:51
AKA: Ron R
Since the Jaguar lights aren't changing color, it sounds like they're not getting any PWM signal from the controller. Since you said you're using the unmodified framework code, that should work in arcade mode. Are the Jaguars connected to the correct PWM outputs? Are the joysticks connected to the right USB ports? Do you have the enable/disable dongle connected to the competition port, with the system enabled?
Unread 08-01-2009, 16:14
FRC1612's Avatar
FRC1612 FRC1612 is offline
FRC #1612 (Robo-Sharks)
FRC1612 is an unknown quantity at this point
Over here at 1612, we had the exact same problem as you. Our wiring was correct and everything else worked, it was just that the Jaguars did not respond. We followed a few steps and now it works:
(we don't know which one of these fixed the problem)
1) Checked and replugged in all of our wires to make sure they were inserted correctly.
2) Downloaded the default code.
3) Re-imaged the cRIO.
4) Noticed that switching to autonomous mode lit up lights we hadn't seen before on module number 8 (the only module in the cRIO that has LED lights), this was the desired function of the autonomous mode of the default code.
5) Hit the reset button on the cRIO.
6) Plugged the joysticks into a computer (Windows running in a Virtual Machine)
7) Plugged the joysticks into the Driver Station and restarted it.
Again, some of these steps are probably unneeded and as we don't know which step(s) fixed our problem, we made sure to list everything we did.
Thanks for the other comments,
-1612 Robosharks
Vex Ultrasonic Sensor not responding SomeoneKnows Programming 6 18-12-2007 16:48
Camera Not Responding To Code itzrobz Programming 2 05-02-2006 12:47
grab frame not responding ahmed LabView and Data Acquisition 4 28-01-2006 10:49
CMUcam default code not responding Kyveck Programming 29 26-01-2006 16:25
STAMP II not responding to computer archiver 2000 4 23-06-2002 22:24
