Go to Post I guess we're going amish this year. - Jon Anderson [more]
Unread 05-01-2009, 19:22
Sam2197's Avatar
Sam2197 Sam2197 is offline
FRC #2197 (Las Pumas)
Team Role: Driver
Sam2197 will become famous soon enough
VIDEO of our bot moving
this is just a thrown together drivetrain to see how it handles on its own and everything. even on the slick tile it still was not too hard to accelerate.
http://tinypic.com/player.php?v=153886g&s=5
Unread 05-01-2009, 19:32
1708xMr.Roboto's Avatar
1708xMr.Roboto 1708xMr.Roboto is offline
Eddie
AKA: Eddie
FRC #1708 (AMPED Robotics)
Team Role: Driver
1708xMr.Roboto will become famous soon enough
Send a message via AIM to 1708xMr.Roboto Send a message via MSN to 1708xMr.Roboto
Re: VIDEO of our bot moving
How's the handling on that bad boy? Didn't look half bad, Keep up the good work. We are going to put the new wheels on last years bot and get some practice on the class room floor.
Facebook 1 - Chief Delphi 19382193
Unread 05-01-2009, 19:35
Sam2197's Avatar
Team Role: Driver
it really wasnt that bad. im sure there will be a little difference on the actual playing surfaces. and with a trailer. but for bein like 30 pounds or whatever it was. it wasnt too bad. we just used a vex controller since our programmers are still playing with the new stuff. i tried getting the video on tile but it wont upload for some reason.. it accelerates pretty nice and doesnt slide around too much either. still maneuverable i will try to get another video to work. we tried pushing a trash can also.. not much luck there. we slid a lot then but that was probably the equivalent of another bot.
Unread 05-01-2009, 19:59
Sam2197's Avatar
Team Role: Driver
second video. http://tinypic.com/player.php?v=4uxkwp&s=5
Unread 05-01-2009, 20:33
It's not as hard to accelerate as I thought it would be.
I think with a heavier robot, you'd drift more (more momentum). Compare your video to our video: http://www.youtube.com/watch?v=u8aqjM1mmEs
Unread 05-01-2009, 20:37
Sam2197's Avatar
Team Role: Driver
yea you do drift a bit more. but think about what that trailer will do. it will either help stop that or make it worse. or both depending on the situation. it can either slow or stop you from drifting or it can back it worse. hopefully we get a permanent frame set up and a manipulator built in the next week or two so we can do some trial and error.
Unread 05-01-2009, 20:38
Darkcrosbone Darkcrosbone is offline
Master of....nothing actually...
FRC #0956
Darkcrosbone will become famous soon enough
yeah yours drifts more... but it doesn't really look hard to handle to me... use drifting to your advantage...
Unread 05-01-2009, 20:40
Sam2197's Avatar
Team Role: Driver
i think the team that devises a drive with a four wheel drive setup like a car will do very well. steering and driving like a car can help pull you out of those drifts
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Oh man, seeing these videos makes me really excited for this year! I can only hope there will be many pro-drivers that will be able to make their robots soar and make the slick movements.
Can't wait to be field reset at FLR and be so close to the action.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 05-01-2009, 20:46
Sam2197's Avatar
Team Role: Driver
something i noticed about your video is that your robot is the long and narrow set up. maybe if you try the wide and short it will help with the drifting. i think it will because you dont have as much weight slinging around
Unread 05-01-2009, 20:48
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
We put some rover wheels on an old robot (not the greatest configuration to put 4 wheels on what was a 6 wheel drive), and put it on regolith. It was rather hard to accelerate, and I doubt it was because of how we had to put the wheels on (front and middle wheels). Because some weight had previously been taken off, we put two 50 pound weights on the robot (on the right and left sides, between the wheels). Turning was also difficult, and our joysticks will have to be scaled.
Unread 05-01-2009, 20:52
Sam2197's Avatar
Team Role: Driver
can you post pics of when you did.
Unread 05-01-2009, 20:55
Alumnus
I'll try to see if we can do it again, the robot's been put in the closet for now while we do design. We didn't take any video or pictures that I know of. I can say that it was actually difficult to get it to move since the wheels would slip pretty readily for us. By the way you can kind of kick it around transversely relatively easily.
Unread 05-01-2009, 20:56
Sam2197's Avatar
Team Role: Driver
ok are you guys planning on going the narrow or wide orientation
Unread 05-01-2009, 21:01
FRC #0956
we were thinking more of wide
Moving bot once targeted on the light bronxbomber92 Programming 10 30-01-2007 12:33
Name our Battle bot Greg Needel Chit-Chat 31 02-06-2005 19:17
Our Bot amateurrobotguy General Forum 11 22-02-2005 14:51
pic: Our Bot CD47-Bot Robot Showcase 0 04-03-2003 19:21
1158 our bot Raul@13 Robot Showcase 5 14-02-2003 19:54
