Go to Post If you think it is such an outrage, then be a do-er and not a talk-er. - BrianBSL [more]
Unread 05-01-2009, 19:39
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Re: Downloading code- DS says "No Code"
Originally Posted by brianc217 View Post
well the ds will always say no code until you set the code as startup code. you do this by right clicking 'build specifications' in the project explorer window and selecting build. a progress bar should appear and once that is complete you right click 'build specifications' another time and select 'run at startup'. can you ping the ds and crio?
Thats slightly right.
The DS will only show "No code." unless you have set the code to start on power. Otherwise, it will show the battery power after as you flash code (deploy for debugging) to the robot, if you don't download any temporary code and don't have a startup code - the DS will say "No code."
-Tanner
"Battery: No Code" after uploading .out file to cRIO knine143 FRC Control System 1 20-12-2008 22:14
Screenshot of "code not understood" or similar error needed! Elgin Clock Programming 3 17-02-2006 22:06
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
Code Errors With "Bells and Whistles" Ryan O Programming 2 31-01-2006 19:29
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
