Go to Post I don't understand why it should matter if your robot is 100% student built, 100% engineer built or somewhere in between. As long as you are Inspired (I word again) FIRST is getting its point and primary goal across. - [more]
Unread 05-01-2009, 20:54
dmlawrence dmlawrence is offline
MIT '14
FRC #1751 (Warriors)
dmlawrence is an unknown quantity at this point
Is it worth it to implement traction control?
If a team implements traction control, they will see an increase of at most 9.6% in the time it takes to get somewhere. Will this type of change really make a difference in the game?
Unread 05-01-2009, 21:01
nitsua60 nitsua60 is offline
FRC #2785 (Prometheus)
nitsua60 will become famous soon enoughnitsua60 will become famous soon enough
Re: Is it worth it to implement traction control?
Originally Posted by dmlawrence View Post
... an increase of at most 9.6% in the time it takes to get somewhere....
Can you describe how you got this result? I assume it's by calculating a max acceleration from mu_s vs. mu_k for controlled vs. non-, and running at that acceleration over the longest path possible? If nothing else, it'd be illustrative for a lot of the high-schoolers to see the math done out.
Unread 05-01-2009, 21:02
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
Is it an increase or decrease in time? If it's a decrease, yes, it is by all means worth it. If it's an increase, then it is up to your drivers; the advantage of traction control would be that your drivers would not have to worry about slipping. Most teams who have drivers experienced in road ice-driving rely on being able to feel when the tires begin to slip; this will not be possible, but the robot can detect it for you.
Whether it is worth it or not will rely on your team. I suggest talking to your programmers and drive team together.
I cut myself shaving with Occam's razor.
Unread 05-01-2009, 21:04
President, VEX Robotics, Inc.
Our testing on the actual surface with the actual trailer shows us that when you are not slipping you will get up to speed at least 30% faster than without and for turning it saves at least 50% of the time. Trying to rotate the goal or rotate aroiund the goal from a dead stop is brutal if you are slipping the wheels.
Unread 05-01-2009, 21:13
MIT '14
Actually, the first number I quoted was just a mental approximation. Here's a more exact number:
Mu changes from .05 to .06 - an increase of 20%.
Force of traction = mu * normal force, so traction also increases by 20%.
Max acceleration = Force of traction / mass, so acceleration also increases by 20%.
Time = sqrt(2 * distance / acceleration), so for a given distance, a 20% increase in acceleration corresponds to 1/sqrt(120%)=91.3%, or an 8.7% decrease in time.
This doesn't seem to match up with the results mentioned above.
Unread 05-01-2009, 21:28
DonRotolo's Avatar
Back to humble
FRC #0832
Also note this thread.
Implementing Traction Control for an advantage in the 2009 game DonRotolo Programming 143 27-02-2009 11:53
Please Help, Don't Know How to Implement Tank Drive in LabView CVassos NI LabVIEW 5 24-12-2008 16:55
Traction Control Algorithm Mr. Lim Programming 3 20-01-2004 14:26
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
