Go to Post Holy cow! Five years in FIRST and it only gets better! Skyway has supplied wheels to FIRST for ten years. Ten years ago Dean called Ken for wheels. Ken said yes. Man, we love helping you guys and gals get good wheels. ;) Bart at Skywaywheels.com - SkywayWheels [more]
View Poll Results: Rear wheel drive vs. Front wheel drive vs. All wheel drive
All wheel drive 110 88.71%
Rear wheel drive 7 5.65%
Front wheel drive 7 5.65%
Voters: 124. You may not vote on this poll
Unread 05-01-2009, 21:33
Josh363663 Josh363663 is offline
AKA: JOSH FARROW
FRC #1529 (Cyber cards)
Josh363663 can only hope to improve
4 wheel drive vs. 2 wheel drive
we have been debating whether all wheel drive or front wheel drive or rear wheel drive was better.
Unread 05-01-2009, 21:54
Collin Fultz's Avatar
Collin Fultz Collin Fultz is online now
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Re: 4 wheel drive vs. 2 wheel drive
General rule of thumb is that you want any wheel touching the ground to be powered. If not, you're cutting into your team's available pushing force.
Collin Fultz
Unread 05-01-2009, 22:17
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
Indeed. If you are imparting robot weight on a wheel, make sure it is powered.
Unread 05-01-2009, 22:23
scottyh2006's Avatar
scottyh2006 scottyh2006 is offline
AKA: Elmo (and what you gonna do about it)
FRC #0564 (Ditigal Impact)
scottyh2006 is on a distinguished road
all wheel drive will be the best
Good Luck to all
Unread 05-01-2009, 22:38
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
That being said, you really want your weight as far back as possible so that your pivot point is as close to the hitch pivot. That reduces the moment that the trailer imparts on you robot, which it needs to counteract to turn, and will allow you to turn better.
Unread 05-01-2009, 23:10
eNyoron eNyoron is offline
Captain, Programmer, Clueless.
FRC #1787 (untitled.txt (as of now))
eNyoron is an unknown quantity at this point
Send a message via AIM to eNyoron
Between rear and front wheel drive, it's really not viable to use a rear wheel drive unless you don't plan on ever exchanging an empty cell... or being pushed into a corner. That portion is carpeted and if you use rear wheel drive to get there, you're going to end up with the front wheels on the carpet with high traction and the powered wheels on the regalith with low traction, making it incredibly difficult to move. And backing into the corner wouldn't work either, there's a trailer in the way.
Unread 06-01-2009, 07:20
smartkid's Avatar
smartkid smartkid is offline
Boom!
AKA: Cody Smith
FRC #1902 (Exploding Bacon)
smartkid has a spectacular aura aboutsmartkid has a spectacular aura about
Where your weight goes is up to you but please know that any and every wheel touching the ground needs to be powered! Also know that your bot should weigh 119.99999 lbs (without battery and bumpers).
Unread 06-01-2009, 07:49
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
My recommendation would be to run some tests with the kit chassis. We subbed some wheels out on a 4x4 chassis last night and ran it on the FRP and carpet. We did a long wheel-base and a short wheel base. We also shifted the CG from 50/50 to almost all on the rear or the nose. All of these are without the trailer so far, so we will try those tonight.
All I can say is I would recommend doing a few tests for yourselves. The dynamics are very different on the carpet vs. on the FRP. Set-ups that were nice and controllable on the FRP wouldn't turn if two side wheels got on the carpet, and set-ups that were easy to turn off the carpet were very squirelly on the FRP. Also, the bot lateral grip seemed a lot lower than the inline grip.
That brings up a very important point, there is a hierarchy when you design:
Ideas are great, but can often be flawed.
Fully thought out theories are better, but often involve a lot of assumptions.
Models (calculations and 3D models) are often made of some tests and measurements and some assuptions.
Test based data is even better yet especially if it validates your model assumptions.
Prototypes can be even more accurate.
My point on this is I have read through a lot of threads on how these bots should be built and how they will behave. I have a lot of vehicle dynamics experience, and I was still surprised by a couple of our tests last night.
Unread 06-01-2009, 08:07
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
I am going to have to respectfully disagree. Having lived in snow/ice conditions for most my life, the best option is FWD with Rear wheel steering. Weight must be over the front wheels and can be done due to the trailers weight so you font tip over. It is much better to pull weight than push when it comes to this subject. Transverse friction is used by the rear wheels to guide the bot to turn. Also as for the trailer, since sway bars are not used (i tow trailers all the time) all of the weight will be centered and pulling at the tongue of the trailer. So putting the weight at the back would epically screw you over since it would want to lift the front wheels off the ground thus taking powered wheels off the ground (in any set up)
Edit: All wheel drive might help but might be wasting power, motors, and battery life...
(i have done some tests and this is what i get, but its up to you)
"Measure once, cut twice... wait... what?"
"Two things needed to build a robot.. WD40 for the things that don't move but should, and Duct tape for the things that move but shouldn't"
Unread 06-01-2009, 08:27
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
All wheel drive absolutely helps.
The physics reason for all wheel drive is this:
1) Let's say your robot has 4 wheels
2) Each of these wheels supports some fraction fi of your robot's weight. The sum of all Fi = 1.
3) Each wheel will thus have a normal force of mRobot*fi*g = 9.81*mRobot*fi
4) Each wheel will thus be able to generate (if powered) a frictional force of
Ff = u*Fn
Ff = 0.06 * (9.81*mRobot*fi)
Ff = 0.5886*mRobot*fi
5) Your robot's total potential frictional force is the sum of the frictional forces of all of its driven wheels.
6) For an all wheel drive robot, FfRobot = 0.5886*mRobot (because Fi sums to 1)
7) For a 2WD robot with its weight evenly distributed, we know all the Fis are 0.25 (due to equal weight), but only two of them are driven. So FfRobot = 0.2943*mRobot, or half of the AWD's robot full force.
So based on 5), 6), and 7), we know that by choosing not to drive some of your wheels, you are throwing away potential friction. Wheels that are touching the floor while the robot is driving and are not powered are completely wasting potential friction. A robot with its weight evenly distributed over 4 wheels that only drives two wheels will be two times slower than an identical all wheel drive robot. The two wheel robot could potentially employ a very complicated suspension so that its weight shifts onto its driven wheels when acceleration or decelerating, but it would be a waste of time when you could just drive all four wheels.
Unread 06-01-2009, 08:34
AKA: Michael
if you are going to attempt to prove me wrong, at least understand my argument. I never said an even weight distribution, in fact i did say WEIGHT OVER THE FRONT DRIVE WHEELS, plus my system cuts down on weight thus allowing you to allocate that precious weight to other areas of the robot like the heavy control system, or ballast weight that you can add where needed...
Unread 06-01-2009, 08:41
Bongle's Avatar
Yes, but even with an uneven weight distribution you're losing pushing power. Even if you stack absolutely everything over your driven wheels, you're probably still losing 10-20% of your pushing power from the weight that will inevitably be over your undriven wheels. Plus you're adding a large design constraint in that all your heavy mechanisms must be in a column over your driven wheels to maximize force.
I understand your idea (though I did gloss that over in my original post, sorry) and it is definitely the most optimal way to implement a 2WD system, I just think that _any_ 2WD system is far from optimal this year.
Unread 06-01-2009, 08:46
AKA: Michael
well from concept everything is in the front anyway, but in this situation pushing power doesn't matter. I you want control you want pulling power. The same reason drift cars are rear wheel drive is the same principal rear wheel drive results in loss of control, and 4wd is going to work too hard to steer sicne the wheels would rather slip inline than transverse (which makes skid steer out of the question) i will admit that 4wd is a valid point, but all drive systems of this year have MAJOR tradeoffs, thus making not one type (except for rear wheel drive) the best, it will be interesting to see at competition....
Unread 06-01-2009, 08:54
Nuttyman54's Avatar
Mentor, Tactician
Agreed. My comments were was based upon the assumption of a standard kit style frame with no steering and the choice being between 2 or 4 wheel drive. Most steered mechanisms will be better than that, but if you are limited to a standard kit drive system, it is my experience with the kit base and attached trailer that the more rearward your pivot is, the better able you are to turn.
Unread 06-01-2009, 08:57
AKA: Michael
i see, the introduction of a powered steering system changes things quite a bit...
6 wheel drive Shaggy1323 Technical Discussion 3 28-03-2008 17:50
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
