Go to Post A lot of students decribe FIRST as the best thing that happened to their life. Once a student gets hooked, they don't want to leave FIRST for any cause. I am one of them. - Arefin Bari [more]
Unread 05-01-2009, 20:41
Darkcrosbone Darkcrosbone is offline
Master of....nothing actually...
FRC #0956
Darkcrosbone will become famous soon enough
<R06> normal wear and tear
in rule <R06> it says "The surface tread of the ROVER WHEELS may not be modified except through normal wear-and-tear." does this mean we can put it on a really fast moter and just normally grind it on something to get grooves on it which would make more traction?
Unread 05-01-2009, 20:45
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
Re: <R06> normal wear and tear
1 will this end up helping w the grip?
sorry we haven't tried the wheels yet btw..
umm also according to this line i dont think what you are thinking of doing will work because:
The intent of this rule is that the ROVER WHEELS be used in as close to their “out of the box” condition as possible, to provide the intended low-friction dynamic performance during the game
as close to their out of the box condition as possible, so by doing that you are violating that rule arent you?
Unread 05-01-2009, 20:48
FRC #0956
ic ah yeah your right my bad
Unread 05-01-2009, 20:53
kirtar kirtar is offline
Alumnus
kirtar will become famous soon enough
Either way, I'm not sure that doing that intentionally would be considered "normal wear and tear" although it may look like it (difficult to prove... don't do it). Also, through your method, it sounds like you would be breaking the following in the same rule
Specifically, the addition of cleats, studs, carved treads, alterations to the wheel profile, high-traction surface treatments, adhesive coatings, abrasive materials, and/or other attachments are prohibited.
You'd somewhat be "carving" it and by the word "grind" you're at least applying an abrasive material.
Unread 05-01-2009, 21:02
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
Right but what if our team's testing area only consists of a back room rough concreate floor that doesnt get much wear and tear, leaving it highly abrasive?
"Measure once, cut twice... wait... what?"
"Two things needed to build a robot.. WD40 for the things that don't move but should, and Duct tape for the things that move but shouldn't"
Unread 05-01-2009, 21:03
FRC #0956
hehe EXACTLY!!!! that would be classified as "wear"
Unread 05-01-2009, 21:57
Normal wear and tear would, to me, be just what you'd get from driving around on something that is close to the field surface. If you show up at an event I'm at and you aren't exhibiting the typical properties of the wheels, I *might* talk to the inspectors. I have no idea of the wear characteristics, so I'm not sure it'll be easy to spot.
Unread 05-01-2009, 22:14
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
I wonder if maybe the inspectors will go around giving teams replacement wheels if they deem there is too much wear on the current ones. Considering they made people use these wheels, they ought to be providing replacements at the competitions.
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
Unread 05-01-2009, 22:21
REVving up for a new season
FRC #2848 (All-sparks)
I honestly think that if you know you are going to have to drive around on a rough surface and it might scuff up the wheels, you should buy a second set of wheels and change them out before ship. That will be the only way to ensure that your wheels are close to out of the box.
Remember it is each team's own responsibility to comply with the rules, and if you don't you are at risk of not being able to play. Honestly I would rather be changing my weels to a new set at my shop before ship then in my pit on Thursday night so I can pass inspection.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 05-01-2009, 22:32
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
I think normal wear and tear would constitute a layer of small scratches and that would be it. it would be pretty easy to tell if these wheels were used to do burnouts on an asphalt surface to an inspector, imo.
also, it would appear as if what you are saying is in violation of the nature of the rule, as it is there to provide the intended low gravity dynamic.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 05-01-2009, 22:33
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Come on guys, don't modify the wheels. The rules state no modifications to the wheels and "ALMOST NEW WHEELS".
R.C.
MadTown Robotics Team 1323
Unread 05-01-2009, 22:40
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
I'm not concerned too much with people purposely modifying the wheels, but what if you are competing in three or four competitions and your wheels are excessively worn down? Are the inspectors going to call you on it? If they do, and you have to change your wheels will they provide you with replacements?
I am always doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
--My Life in FIRST--
2009 Detroit Xerox Creativity Award
2009 Detroit District Finalists - Thanks to 1856 and 2620
2009 Kettering District Quarter-Finalists - Thanks to 1504 and 1025.
2008 Kettering Kickoff Champions - Thanks to 67, 1075 & 2619
2008 MARC Finalists - thanks 67 & 226
2008 Great Lakes Finalists - thanks 66 & 217
2008 Western Michigan Semi-Finalists - thanks 2337 and 1504
2008 GLR Judges Award Winner
2007 Curie Division Champions - thanks 330 and 1270
2007 ARC Champions (13 and 0, plus scoring a double-keeper!) - thanks 1625 and 313
2007 MARC Champions - thanks 1732 and 1023
2007 Xerox Creativity Award - Western Michign
2006 I.R.I. Champions - thanks 71 and 1625
Unread 05-01-2009, 22:41
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
I wonder if replacement wheels will be available at regionals in case of unexpected wear and teams don't have their own extras.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 06-01-2009, 01:15
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
I really don't think modifying your wheels through any sort of semantics related to "normal wear-and-tear" would be Gracious Professionalism. You know what the rules are meant to do (make it so you don't modify your wheels to an advantage) and you shouldn't subvert that.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 06-01-2009, 04:12
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Alright, yes, teams could, in theory, go drive their robots on the road outside their building to scuff up the wheels and call it "normal wear and tear". It's up the every team to follow the rules, there's a million ways around this rule and none fall anywhere under "gracious professionalism".
That said, does scuffing up the wheels actually help anything? Assuming the competition floor is completley flat (no gouges, grooves, etc.) then there would be nothing for the scuffs on the wheel to interlock with. Thus, all that could possibly propel the robot would be frictional forces, which are surface area independent (i.e. roughing up the wheels won't help.) Am I missing something?
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
PID vs Normal loops 3DWolf Programming 20 14-12-2007 13:41
Hobbies, normal and unusual Jill1022 Chit-Chat 61 29-04-2005 08:33
back to school...tear CourtneyB Chit-Chat 18 28-04-2005 14:07
Well, is it normal for me not to be in FIRST Robotics and post here? JKis6622 Chit-Chat 3 13-03-2004 15:46
R06 - weight and configuration jimfortytwo Technical Discussion 6 18-02-2004 08:06
