Go to Post Is FIRST making it too easy?... yes they are making it easier than years past. But I would also say that does that matter? If students are still inspired to pursue more advanced designs and eventually a career in the technology sector we still have met our ultimate goal. - MikeDubreuil [more]
Unread 05-01-2009, 22:56
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
R06 clarification
Reading rule six it says you must use the provided rover wheels to provide traction. Does anyone else think the means for driven wheels only?? Could we use sticky wheels for steering?
Thanks
Bruce
Unread 05-01-2009, 23:01
Re: R06 clarification
Thanks
Bruce
It means no wheels that aren't rover wheels.
<R06>
ROBOTs must use ROVER WHEELS (as supplied in the 2009 Kit Of Parts and/or their equivalent as provided by the supplying vendor) to provide traction between the ROBOT and the ARENA. Any number of ROVER WHEELS may be used. The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). No other forms of traction devices (wheels, tracks, legs, or other devices intended to provide traction) are permitted. The surface tread of the ROVER WHEELS may not be modified except through normal wear-and-tear. Specifically, the addition of cleats, studs, carved treads, alterations to the wheel profile, high-traction surface treatments, adhesive coatings, abrasive materials, and/or other attachments are prohibited. The intent of this rule is that the ROVER WHEELS be used in as close to their “out of the box” condition as possible, to provide the intended low-friction dynamic performance during the game
If it contacts the ground, it provides traction. If it provides traction, it must be a rover wheel. Therefore, if it contacts the ground, it must be a rover wheel.
Unread 05-01-2009, 23:30
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
EricH is right. I had hoped to make a walker robot with plungers or something. But, alas that's not allowed either.
The only way i could see you not having to use the rover wheels would be to make a hovercraft.
Unread 06-01-2009, 00:56
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
What's stopping you from mounting the wheels locked and making a walker with those?
Sure, you wouldn't get any additional traction and could easily be pushed.. but hey, it's a walker bot =P
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 06-01-2009, 01:02
keen101's Avatar
Ubuntu Linux User
heh. Yeah, i did think about that too. It would still be cool, but probably not worth it.
Unread 06-01-2009, 01:09
I would say that that is legal PROVIDED that the rest of <R06> is followed. That could pose an issue, because the axis of rotation must go through the wheel hub.
Unread 06-01-2009, 17:13
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
No problem. Mount the wheel normally, then put a friction brake on the top.
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
<R06> normal wear and tear Darkcrosbone Rules/Strategy 54 27-01-2009 18:03
Conflict with rules R05 & R06? Wayne Doenges Rules/Strategy 17 04-02-2007 14:34
R06 - weight and configuration jimfortytwo Technical Discussion 6 18-02-2004 08:06
Rule <R06> Jack Technical Discussion 18 11-01-2004 13:36
