Re: detecting your own alliance(C++)
They also need to make manuals that are accurate. Their FRC Control System pdf #5 on their FRC Control System page has so many errors it wasted a lot of my winter break
Before the match, you have what's called a "constructor" period in the SimpleRobot.cpp template which MIGHT be able to be used to run code in disabled, but my sources haven't tried it yet. If you use the BuiltinDefaultCode.cpp template (iterative template), there's a class for disabled mode. Basically, constructor is the equivalent of Initialize() or IO_Initialization() of the PIC version of WPILib, except I think it runs more than once. Using the disabled mode period, you can run code whenever the robot is disabled, the controller is just introverted; you can read inputs and run code, but you cannot run motors or set outputs until you're enabled.
That being said, that period is the perfect time to figure out where you are and what you're doing with the camera right after the cRIO boots up. With the complexity of the control system this year, there is no reason for your processor to have downtime. You can always be reading a sensor or analyzing visual data to find out where your opponents are and where your alliance members are. That way you know where those robots are already, and can track them when they dart off at the beginning of autonomous and plot a projected course for their trailers to meet very nicely with your moon rocks flying through the air But seriously, do use the camera. |
If only just to take rad pictures.
If you examine WPILib, the START_ROBOT_CLASS macro passes startRobotTask() a function that creates an object of your RobotBase derived class. Once it starts the robot task, it creates your object. This is only done once (or at least, only when FRC_UserProgram_StartupLibraryInit() is called). Strictly speaking, FRC_UserProgram_StartupLibraryInit (also defined in the START_ROBOT_CLASS macro) is more like Initialize() or IO_Initialization()... but of course it gets called before your task is created and its probably not a particularly great idea to use it. ![]() |
Inside the WPI library, look in the driverstation.cpp file.
Inside there, you'll find that there is a function to tell you what alliance you are on (also, there is one that will tell you what station you're plugged into, 1,2, or 3) Quote:
| Make your own CNC | whytheheckme | Technical Discussion | 8 | 25-07-2007 02:13 |
| Your Own Team Siggies | Cujo | General Forum | 8 | 26-02-2005 16:01 |
| any of your regional "buddies" with your in your alliance? | Alex Cormier | Championship Event | 12 | 08-04-2004 04:20 |
| How do you tell whether your sensor is detecting a crate or the diamond plate? | Greg Ross | Technical Discussion | 4 | 13-01-2003 19:02 |
| Making your own gearbox? | ChaosMonkey | Motors | 15 | 25-05-2002 11:07 |
