Go to Post Your robot weight goes up after you release the balloons. Re-inspection! - GaryVoshol [more]
Unread 05-01-2009, 21:09
Sauce Sauce is offline
FRC #1245 (Shazbots)
Sauce is an unknown quantity at this point
Terminal creation.
We just made a sub-vi and we need to connect the icon into the program, but there are no terminals on the icon. How do you create the terminals? If it helps, we want an interger to be inputed and a cluster to be outputed.
Unread 06-01-2009, 00:49
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: Terminal creation.
On the front panel window, right click the icon and hit Show Connector.
Play around with adding and deleting connectors and patterns.
To set a connector, click the connector in the icon to select it, then click on your input on the front panel. The connector will change color to the type of connection.
That's the basics of it. =)
EDIT: Attached are 2 pictures.
ID:	7082  Click image for larger version
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 06-01-2009, 01:08
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
You can also do fancy stuff like changing the pattern and such.
You can also design the icon so that they are not completely rectangular and do fun stuff like those mathematical operators
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 06-01-2009, 17:21
Thanks for the help guys we got it.
pic: Our creation hiimcristhian Extra Discussion 12 27-08-2007 14:22
New team Creation?? skibumm101 FIRST Tech Challenge 6 07-06-2006 21:03
#define creation NASAbound1636 Programming 3 02-02-2006 23:40
Robot Creation Help GregTheGreat Technical Discussion 5 23-10-2003 12:09
dean creation archiver 2001 2 23-06-2002 22:47
