Go to Post When it is so boring and slow on here in the summer it is funny how all of us just jump at something technical. - sanddrag [more]
Unread 01-06-2009, 12:54 AM
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Re: detecting your own alliance(C++)
Before the match, you have what's called a "constructor" period in the SimpleRobot.cpp template which MIGHT be able to be used to run code in disabled, but my sources haven't tried it yet. If you use the BuiltinDefaultCode.cpp template (iterative template), there's a class for disabled mode. Basically, constructor is the equivalent of Initialize() or IO_Initialization() of the PIC version of WPILib, except I think it runs more than once. Using the disabled mode period, you can run code whenever the robot is disabled, the controller is just introverted; you can read inputs and run code, but you cannot run motors or set outputs until you're enabled.
That being said, that period is the perfect time to figure out where you are and what you're doing with the camera right after the cRIO boots up. With the complexity of the control system this year, there is no reason for your processor to have downtime. You can always be reading a sensor or analyzing visual data to find out where your opponents are and where your alliance members are. That way you know where those robots are already, and can track them when they dart off at the beginning of autonomous and plot a projected course for their trailers to meet very nicely with your moon rocks flying through the air But seriously, do use the camera.
Unread 01-06-2009, 09:10 PM
Red Mage's Avatar
Red Mage Red Mage is offline
Owner of Holistic Omniscience
FRC #1546 (Chaos Inc)
Red Mage is on a distinguished road
Send a message via AIM to Red Mage
If only just to take rad pictures.
Don't Blink. Blink and you're dead. Don't turn your back. Don't look away. And don't Blink. Good Luck.
Unread 01-07-2009, 12:01 AM
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
A constructor is a standard C++ language feature, and constructor only gets called once per created object, and only when the object is instantiated (for example, if you do a "new ObjectName()" then a new object is created and a constructor is called.. of course there are other ways to create an object also).
If you examine WPILib, the START_ROBOT_CLASS macro passes startRobotTask() a function that creates an object of your RobotBase derived class. Once it starts the robot task, it creates your object. This is only done once (or at least, only when FRC_UserProgram_StartupLibraryInit() is called).
Strictly speaking, FRC_UserProgram_StartupLibraryInit (also defined in the START_ROBOT_CLASS macro) is more like Initialize() or IO_Initialization()... but of course it gets called before your task is created and its probably not a particularly great idea to use it.
Unread 01-11-2009, 05:13 PM
Shalmezad Shalmezad is offline
FRC #2619
Shalmezad is an unknown quantity at this point
Cool Re: detecting your own alliance(C++)
Inside the WPI library, look in the driverstation.cpp file.
Inside there, you'll find that there is a function to tell you what alliance you are on (also, there is one that will tell you what station you're plugged into, 1,2, or 3)
DriverStation::Alliance DriverStation::GetAlliance()
if (m_controlData->dsID_Alliance == 'R') return kRed;
if (m_controlData->dsID_Alliance == 'B') return kBlue;
wpi_assert(false);
return kInvalid;
Have fun
Make your own CNC whytheheckme Technical Discussion 8 07-25-2007 02:13 AM
Your Own Team Siggies Cujo General Forum 8 02-26-2005 04:01 PM
any of your regional "buddies" with your in your alliance? Alex Cormier Championship Event 12 04-08-2004 04:20 AM
How do you tell whether your sensor is detecting a crate or the diamond plate? Greg Ross Technical Discussion 4 01-13-2003 07:02 PM
Making your own gearbox? ChaosMonkey Motors 15 05-25-2002 11:07 AM
