Go to Post We draw the line when our students are more affectionate towards the tools rather than eachother. - ksafin [more]
Unread 04-01-2009, 04:01
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Frictional Discrepancies
Originally Posted by AndyMark
Tread Material: White Acetal
Coefficient of Friction with plastic surface: 0.5 Static, 0.4 Dynamic
Originally Posted by The Kit of Parts, 10.2.4.1
The wheels supplied in the 2009 KOP are very different from previous years’ kit wheels. The tread material is Celcon M90, and has the following coefficients of friction on white, rippled fiberglass plastic sheet
Inline, static: 0.06
Inline, dynamic: 0.05
Transverse, static: 0.14
Transverse, dynamic: 0.10
There's an order of magnitude between the two sets of published figures (for the inline case, assuming that's how AndyMark tested them). This makes design difficult.
Any guesses as to which is accurate? I'd surmise that AndyMark tested early-production wheels, and that FIRST is quoting from a generic material specification, but that's entirely speculative.
I looked up a Celcon datasheet for bearing design, and (on page 67) they suggest that the dynamic coefficient of friction of Celcon on Nylon 66 is around 0.17, and that for Celcon on steel, it will be between 0.15 and 0.30, depending on speed and pressure. That's a third set of data (albeit only vaguely appropriate to our application), and it falls somewhere in between the other values.
Originally Posted by The Arena, 6.2.1
The REGOLITH is made of “Glasliner FRPtm” gel-coated, fiberglass-reinforced, polymer material.
Also, note that Section 6 suggests that the floor is the gel-coated Glasliner FRP, while Section 10 (above) states that the sheet is "rippled". According to this and this, the "pebbled" and gel-coat finishes are mutually-exclusive options, so one section must be misleading. Which type of material was used to generate AndyMark's test numbers? Which material will appear at the competitions? (Apparently at the NH kickoff, it was the textured stuff.)
Unread 04-01-2009, 08:09
President, VEX Robotics, Inc.
Re: Frictional Discrepancies
Tristan,
As far as the gel coat is concerned, both the pebbled and smooth are gel coated. the premium smooth finish has a thicker layer of gell coat. The gel coat is necessary so the fibers don't start poking out of the plastic after the molding. I am certain the pebbled finish is what we want.
Unread 04-01-2009, 11:22
paulcd2000's Avatar
paulcd2000 paulcd2000 is offline
Accidentally speaks in C
AKA: Paul Dagnelie
FRC #1719 (The Umbrella Corp.)
paulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the roughpaulcd2000 is a jewel in the rough
Send a message via AIM to paulcd2000
i would trust the manual numbers, because andy-mark is talking about "plastic" whereas the manual specifically refers to fiberglass. also, just by looking at the demo robots, i think mu is way lower than .5 otherwise, the robots wouldn't slid the way they did.
"People don't say 'It's just a game' when their team is winning!" -- Scott Adams
5.5 students (on average)* $7/h *210 hours/student= $8085 of labor, all volunteered (not counting mentors', who are each that much)
We have blades on our robot?! ***sweeeeeet***
There are 11 types of people in the world. Those who can read binary, those who can't, and those who say this joke is supposed to be, "There are 10 types of people in the world. Those who can read binary and those who have a life."
Unread 04-01-2009, 13:15
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
I think it's pretty clear that the AndyMark numbers are wrong. From what I remember of previous years with rubber on carpet, a mu of .6 or so was decent, and more than .9 was absolutely amazing. Mu of 0.5 would be only a small step down.
The numbers FIRST quoted sound like they were derived from testing, given that the manual has both inline and transverse coefficients.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 04-01-2009, 15:58
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
It does make a huge difference, though. If the numbers from AndyMark are correct, it means inline > transverse, which makes skid steer a reasonable choice. If the numbers from FIRST are correct, it means the opposite.
Unread 04-01-2009, 16:56
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
OOOOPS! Sorry all. Our numbers that WERE posted on our website were wrong. I was hurrying through adding these websites, and I just erroneously missed a "0" in my number. 0.05 is correct for static friction. This was tested between the Rover Wheel and the playing field surface (not carpet).
Thanks for pointing this out, Tristan.
Andy Baker
<edit> ... by the way... if anyone catches something silly like this from me again, feel free to drop me a PM or email at "andyb AT andymark.biz". These days, I am fairly busy and don't always get to check this site.
Unread 04-01-2009, 21:31
AndrewN's Avatar
AndrewN AndrewN is offline
it's alive!
AKA: Andrew Nicholson
FRC #1778 (Chill Out)
AndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really nice
Doing an incline plane test with four wheels and a frame we found almost no difference between the lateral and transverse static COF as measured by the angle of the incline. We are using the correct surface too.
Just to make it clear:
1. Point the locked wheels down the incline and gradually raise one end of the surface until the frame breaks free slides down. Measure the height at which the frame breaks free (8.5" over a 6ft sheet). This is a measure of the lateral static COF (tan of the angle between the horizontal and the incline). Our result is around 0.12 or an angle of 6.7 degrees.
2. Turn the frame 90 degrees. The wheels are now sideways down the slope. Repeat test. This is the transverse static COF.
Our result 8.5 - 9". Almost the same as the lateral value.
We expected that the heights of the two tests should almost be a factor of two or more different given 0.6 and 1.4 as the printed static COFs.
Can other teams please repeat this test and report the angles they are finding for both lateral and transverse static friction.
Andrew Nicholson
2011 FRC Robot Inspector (Seattle, Portland)
Mentor FRC 1778 "Chill Out", FTC 3018, 3940 "Hawks", 4434 "Heat Misers"
"Everything should be made as simple as possible, but no simpler."
Unread 05-01-2009, 07:14
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
As an engineer, I have an issue with the "lateral" and "inline" numbers. On an ideal surface, and the interaction between the wheels and "regolith" this year com as close to ideal as you can get, friction depends ONLY on friction coefficient, and normal force. There is no directionality component. I looked at the wheels, and went to Home Depot and looked at the surface. I can see no reason, theoretical or otherwise, for a difference. As AndrewN's testing shows, in-line and lateral should be identical.
Former Mentor Team 1771
Former mentor Team 4509
Unread 05-01-2009, 07:40
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
My team thought this was weird as well. Our theory is that since the wheels will mostly be spinning forward and back more than they'll be sliding sideways (ignoring any holonomic-type drives), then they'll tend to get heavily scuffed in a forward-back direction. So perhaps after a few matches worth of use, you might see the kind of transverse coefficients that the manual describes.
Unread 05-01-2009, 07:43
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
We measure COF by drag - we simply drag the load with a scale attached on a flat surface.
We are getting around .1 in either direction, dynamic. Static was sightly more (.12 I think).
There is no noticeable difference between dragging it sideways or not with the wheels locked.
Unread 05-01-2009, 09:24
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
My only guess is the testing may have been done on the wheels with the mold lines still on them (not worn)?
Could this be trying to dig into the field material, thus raising the effective CoF?
Unread 05-01-2009, 11:09
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Perhaps you have discovered what's behind the "fish" clue
The transverse/inline ratio is a very critical parameter. If it's no where near the 2.3 advertised, then many preliminary design decisions about drive configuration will be dead wrong. We will try to confirm your findings as soon as we can locate the actual surface material.
It is possible that the ratio changes significantly with normal forces closer to 1/4 of the nominal weight of the robot due to the way the materials deform under load. It could also be that the type of backing underneath the regolith is a factor. The wheels are very hard and provide a very small contact area. If the backing is carpet (rather than a very hard material), there could be a small depression that presents differently in transverse and longitudinal directions. Your numbers may reflect light loading, before such effects manifest themselves. Based on your data it does looks like we will need to confirm the Mu values under a range of loads.
Does anyone know whether the regolith is over carpet?
Good catch.
Unread 05-01-2009, 23:44
SWIM's Avatar
SWIM SWIM is offline
SomeoneWhoIsntMe
AKA: James Meintjes
SWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really nice
Good catch.
From how I interpreted the rules, the entire field is covered in carpet, and the regolith is placed over that.
Unread 06-01-2009, 01:50
Ozeaden Ozeaden is offline
FRC #1388 (Eagle Robotics)
Ozeaden is an unknown quantity at this point
One thing that my team found out is that if u wear down the wheels, you get better traction. With having a rough tire, it will give more of a stick to the flooring material. We tried it on one of our past robots and it worked really good. Just run the wheels on asphalt and run it down a bit. Its not against the rules at all.
http://www.eaglerobotics.com/
Unread 06-01-2009, 02:00
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
Read <R06> and I think you will find you are very wrong, and are now out $100 in usable wheels. This is intentional damage, which is explicitly prohibited by that rule.
A2D Solving the Imaginary Error Function...
Frictional coefficant of wheels on the carpet bobwrit Technical Discussion 11 05-12-2008 07:34
