Go to Post ...six-year-old Libby had dragged her by the hand over to my (M.D./Ph.D) father and said, "Daddy, this is Miss Sally. She's a doctor AND and astronaut. YOU'RE just a doctor." - Libby K [more]
View Poll Results: Rear wheel drive vs. Front wheel drive vs. All wheel drive
All wheel drive 110 88.71%
Rear wheel drive 7 5.65%
Front wheel drive 7 5.65%
Voters: 124. You may not vote on this poll
Unread 06-01-2009, 08:07
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
Re: 4 wheel drive vs. 2 wheel drive
Originally Posted by Nuttyman54 View Post
That being said, you really want your weight as far back as possible so that your pivot point is as close to the hitch pivot. That reduces the moment that the trailer imparts on you robot, which it needs to counteract to turn, and will allow you to turn better.
I am going to have to respectfully disagree. Having lived in snow/ice conditions for most my life, the best option is FWD with Rear wheel steering. Weight must be over the front wheels and can be done due to the trailers weight so you font tip over. It is much better to pull weight than push when it comes to this subject. Transverse friction is used by the rear wheels to guide the bot to turn. Also as for the trailer, since sway bars are not used (i tow trailers all the time) all of the weight will be centered and pulling at the tongue of the trailer. So putting the weight at the back would epically screw you over since it would want to lift the front wheels off the ground thus taking powered wheels off the ground (in any set up)
Edit: All wheel drive might help but might be wasting power, motors, and battery life...
(i have done some tests and this is what i get, but its up to you)
"Measure once, cut twice... wait... what?"
"Two things needed to build a robot.. WD40 for the things that don't move but should, and Duct tape for the things that move but shouldn't"
6 wheel drive Shaggy1323 Technical Discussion 3 28-03-2008 17:50
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
