Go to Post That's co-oper-tastic. - anyheck [more]
Unread 05-01-2009, 23:31
LinuxMercedes LinuxMercedes is offline
Real men use Macs
FRC #1444 (Lightning Lancers)
LinuxMercedes is an unknown quantity at this point
Question Problem debugging code with WindRiver
When I click 'debug' (after setting all the settings per the manual), it launches correctly and stops on the first statement. However, if I step a few times, or set a breakpoint and have it run until then, I get the following error: "<insert some fancy text with hex digits that I don't want to type> The debugger is already attached to debug this exception."
I can't seem to figure out what's wrong...any ideas?
Unread 06-01-2009, 09:34
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
Re: Problem debugging code with WindRiver
To get the actual debug statements you want to open up the target tools. Tn the bottom left corner there should be a box that says remote systems. in that box you should see the system that is your cRio. Right click on that go to target tools->console and that will give you debug statements.
Unread 07-01-2009, 09:35
Real men use Macs
Thanks, Nick. I pulled open the console and saw that the default program was still running--apparently you have to undeploy it, although the manual doesn't say so...
Unread 07-01-2009, 11:10
nickmagus's Avatar
AKA: Nick Clayton
If you download the code rather than just debugging it you will still get debug statements and the code will stay on the robot. When you download code you don't need to undeploy the old code but if you debug code you have to undeploy first.
Problem with Kevin's code Tottanka Programming 5 04-11-2007 13:32
PWM Problem with Default Code kbregler Programming 16 03-02-2007 15:14
Problem with Modified Code Brigander Programming 14 31-01-2007 13:25
problem with the default code MarkVH Programming 7 28-01-2005 00:04
Problem with FRC Default code AsimC Programming 2 11-01-2004 19:22
