Go to Post In my opinion, the hardest part of the competition is not that actual manufacture of the robot, but the design process. It is the enginners that go through the design process all the time that will have the edge in this competition, not the best machinist. - Wetzel [more]
Unread 06-01-2009, 09:55
Greg Peshek Greg Peshek is offline
FLL #2054
Greg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to allGreg Peshek is a name known to all
Re: 4WD Turning Difficulties
Originally Posted by SWIM View Post
But what happens when you put the same tires on the car and the tank?
Being on a team that built an Ackerman steering robot for last year's game (see: http://www.chiefdelphi.com/media/photos/29780) and as a drivetrain guy myself, I can say that the steering robot was a very, very high traction system. In the picture you can see that we used dualie 10" rubber wheels on the differential and 8" rubber wheels in the front. It needed a lot of traction to work.
We used those same 8" wheels on a tank drive in the Aim High game, and the robot had entirely too much traction and essentially "danced" while trying to turn (we have since learned..) So if you extrapolate you can conclude that the high traction environment was needed on the car steering, while completely overkill on the tank drive.
I can't conclusively say that the Ackermann steering requires significantly more traction to work, but from my experience it seems as if it does - and I would have a hard time seeing it working with a lack of traction on the front steering wheels. Take it as you may.
-Greg
IR Difficulties AmitCarmeli Programming 3 11-01-2008 20:49
Technical Difficulties muy dificil Programming 0 13-10-2005 11:25
Default Code Difficulties Drok00 Programming 3 02-02-2005 20:56
FIRST Technical Difficulties at Rutgers aka Scott White General Forum 10 27-03-2002 14:40
