Go to Post I've got much more out of FIRST ever since I stopped and realized I can gain so much more from trying to improve my current team's situation rather than complain about teams who have more. - AdamHeard [more]
Unread 06-01-2009, 10:35
LoveMe_HateMe LoveMe_HateMe is offline
Ashley
FRC #1831
LoveMe_HateMe is an unknown quantity at this point
Wheels?
Can you take one set of wheels off the ground to replace them with another set to change the bots direction?
Unread 06-01-2009, 10:38
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Wheels?
Assuming they are Rover Wheels, and it doesn't cause your robot to exceed the 60 inch max height. There are no rules not allowing this.
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Wheels?
Nothing that I've seen in the rules specifically prohibits that.
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Wheels?
I think i know what you are asking, as we did a drive system like this in the past (2002).
http://www.chiefdelphi.com/media/photos/13478
The only thing I can see that would prevent this is the location of the fixed trailer point you need on your robot, the interaction with the trailer, & potentially the angle your bot is at during the transistion.
As long as you use the correct wheels, I personally don't see anything other than those details to look at as I said above that can cause a hiccup with that plan.
Best bet is to ask the official Q&A system though.
Unread 06-01-2009, 10:44
Matt C's Avatar
FRC #1468 (J-Birds)
Re: Wheels?
I wasn't even thinking of the so called "fixed" hitch.
That does generate an interesting question. Fixed as opposed to what?
Can the wheels in fact be lowered thus raising the trailer point, and the entire robot with it? (I would also think we are only talking about .25-.5" to just barely raise the main drive wheels up.)
So I revise my statement. I would check on Q&A, the implications could be interesting.
You might need to find a way to get the hitch to remain stationary by mounting it to whatever "drops" down to raise up the rest of the robot.
Unread 06-01-2009, 13:06
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
Re: Wheels?
You can do what you suggest and keep height constant if you drop the second set of wheels first and then lift the first set, keeping the "down" position of both sets of wheels the same. Should be no problem with the rules.
- Steve
Unread 06-01-2009, 13:19
MrForbes's Avatar
AKA: Jim
Re: Wheels?
It would be difficult to keep the hitch height constant with a drop center wheel 6WD chassis.
Unread 06-01-2009, 13:36
Matt C's Avatar
FRC #1468 (J-Birds)
Re: Wheels?
You'd also have to worry about breaking out of your 28x38x60 inch envelope with whatever wobble you have.
Unless of course the envelope changes angular orientation with your robot. Otherwise if your robot tips slightly due to collision, you would violate the rule.
Unread 06-01-2009, 13:38
MrForbes's Avatar
AKA: Jim
Re: Wheels?
After our experience last year with not-square sizing boxes, we now know that the upper part of the robot should be significantly smaller than the base, just to prevent hassles like this.
6 wheels with only 2 powered wheels bhsrobotics1671 General Forum 15 14-01-2008 17:28
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
TO much traction??? (ifi wheels or AM wheels) Heretic121 Technical Discussion 9 04-02-2006 12:09
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
Wonder Wheels (aka Side Slip Wheels) Scott358 Technical Discussion 4 08-01-2002 12:36
