Wheels?
Can you take one set of wheels off the ground to replace them with another set to change the bots direction? |
Re: Wheels?
Assuming they are Rover Wheels, and it doesn't cause your robot to exceed the 60 inch max height. There are no rules not allowing this.
Re: Wheels?
Nothing that I've seen in the rules specifically prohibits that.
Re: Wheels?
http://www.chiefdelphi.com/media/photos/13478 The only thing I can see that would prevent this is the location of the fixed trailer point you need on your robot, the interaction with the trailer, & potentially the angle your bot is at during the transistion. As long as you use the correct wheels, I personally don't see anything other than those details to look at as I said above that can cause a hiccup with that plan. Best bet is to ask the official Q&A system though. |
Re: Wheels?
That does generate an interesting question. Fixed as opposed to what? Can the wheels in fact be lowered thus raising the trailer point, and the entire robot with it? (I would also think we are only talking about .25-.5" to just barely raise the main drive wheels up.) So I revise my statement. I would check on Q&A, the implications could be interesting. You might need to find a way to get the hitch to remain stationary by mounting it to whatever "drops" down to raise up the rest of the robot. Last edited by Matt C : 06-01-2009 at 10:52. |
Re: Wheels?
You can do what you suggest and keep height constant if you drop the second set of wheels first and then lift the first set, keeping the "down" position of both sets of wheels the same. Should be no problem with the rules.
- Steve |
#7
Re: Wheels?
It would be difficult to keep the hitch height constant with a drop center wheel 6WD chassis.
#8
Re: Wheels?
Unless of course the envelope changes angular orientation with your robot. Otherwise if your robot tips slightly due to collision, you would violate the rule. |
#9
Re: Wheels?
After our experience last year with not-square sizing boxes, we now know that the upper part of the robot should be significantly smaller than the base, just to prevent hassles like this.
| 6 wheels with only 2 powered wheels | bhsrobotics1671 | General Forum | 15 | 14-01-2008 17:28 |
| Friction coefficients for Omni wheels and Mecanum wheels from AndyMark | Andy Baker | Technical Discussion | 11 | 16-12-2006 19:40 |
| TO much traction??? (ifi wheels or AM wheels) | Heretic121 | Technical Discussion | 9 | 04-02-2006 12:09 |
| Image Discuss: Wheels- you want wheels - more from team 25 | CD47-Bot | Extra Discussion | 10 | 07-09-2003 20:33 |
| Wonder Wheels (aka Side Slip Wheels) | Scott358 | Technical Discussion | 4 | 08-01-2002 12:36 |
