| View Poll Results: Rear wheel drive vs. Front wheel drive vs. All wheel drive | |||
| All wheel drive |
110 | 88.71% |
| Rear wheel drive |
7 | 5.65% |
| Front wheel drive |
7 | 5.65% |
| Voters: 124. You may not vote on this poll | |||
#16
Re: 4 wheel drive vs. 2 wheel drive
right but since there are no sway bars present, the tongue weight and force it exerts will be concentrated at the hitch, if the hitch is in the center of the two steering wheels, the force will be distributed evenly between them giving the needed down force to turn the bot...
#17
To everyone considering not using all wheel drive: DON'T DO IT!!!
I don't care if you are steering, not steering, using 2 wheels or 18. With the limited amount of usable force available you want every wheel touching the ground to contribute to converting normal force into tractive force. Every non powered wheel you have touching the ground will reduce your ability to accelerate and push. |
#18
And by the way, the whole "pushing is better than pulling" thing is more or less a myth. RWD makes more efficient use of it's traction than FWD, no matter what surface they're on. The reason why FWD is better in the winter is that when they're varying levels of traction on different parts of it road, it's easier to control, and understeer is safer than oversteer. Manufacturers don't like selling cars that oversteer, is because the majority of people don't understand vehicle dynamics, and don't have the experience to correct oversteer instinctively. If a RWD car starts to slide out, most people are going to slam on the brakes. This transfers weight to the front of the car, increasing the grip on the front wheels, and decreasing the grip in the rear, causing the car to pivot further. To correct a slide in a RWD car, you need to use steering input and throttle modulation, not panic braking. In the context of Lunacy, where the traction on the regolith is entirely uniform, and it doesn't matter if you slide into other robots, RWD would be far superior. Just because traction is reduced this year doesn't mean that the laws of physics went out the window. FWD still sucks. In fact, it sucks even more this year, because the robots are going to be driving at the limit of their grip all the time. Last edited by SWIM : 06-01-2009 at 11:18. |
#19
8-wheel drive
Use pairs of wheels |
#20
Kind of late, but thought it was worth posting.
Our final configuration uses 48 wheels. |
#21
I want to see that. Got a picture?
#22
#23
I won't be able to watch. Please post a pic or a vid after the fact. Ok?
| 6 wheel drive | Shaggy1323 | Technical Discussion | 3 | 28-03-2008 17:50 |
| Lowered Center Wheel for 6 wheel drive | 987HighRoller | Technical Discussion | 37 | 17-01-2007 01:21 |
| pic: Jester Drive:Mecanum Wheel Drive Train | Ken Delaney 357 | Technical Discussion | 64 | 29-03-2006 22:16 |
| pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! | jskene | Robot Showcase | 25 | 18-02-2005 20:24 |
| 2-wheel versus 4-wheel drive | Ben Mitchell | Technical Discussion | 23 | 07-11-2003 00:50 |
