Go to Post FIRST doesnt care about the weather, and we still need a working robot. - Mike Heinowski [more]
  #31   Spotlight this post!
Unread 06-01-2009, 09:11
Racer26 Racer26 is offline
Re: Defensive Strategies
Well that IS an interesting strategy. There IS precedent for an FRC bot to lack a mobility system (see 2007, and the sitting ramp-bot, sorry dont recall a team number but there WAS a pic on CD)
You might even be able to build a hopper with simple shooter that your descorer dumps the balls into to be able to use them.
IF you could make your descoring mech VERY functional, it might work.
  #32   Spotlight this post!
Unread 06-01-2009, 10:07
pfreivald's Avatar
AKA: Patrick Freivald
Maybe I'm just not that creative, but I don't see how it is possible to extend any kind of cap over the trailer, even half way.
A. You can't extend outside your footprint.
B. The Trailer can't be tipped.
C. The Trailer has to be attached on the outside (convex or flat) of your robot, with a 10" tongue, in a way that the tongue will not touch your bumber while driving...
I suppose that a very short robot might be able to extend backwards to some degree, but a 10" tongue + half the length of the trailer actually seems to be *impossible* to me.
Am I missing something really key here?
Patrick
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #33   Spotlight this post!
Unread 06-01-2009, 10:56
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
But as soon as you start restricting its motion from the inside, I'd call that some form of attaching to.
Realistically, I think this will end up in Q&A very quickly. I would expect that the answer would be something to the effect of "As long as no rules on contact outside the bumper zone are violated, it's fine."
Which then means that all one robot has to do to get you in trouble is tangle you up. If it's done enough, you have to modify your design.
Firstly, vaguely restricting the motion of an object isn't "attaching" to it. Apply that definition to robots, and pinning a robot would suddenly count as attaching to it. It's more on the lines of entanglement, which is judged case-by-case, and you have to actually end up caught up with the trailer.
Secondly, if the GDC restricts this by the contact outside the bumper zone rule, it simply makes it slightly more tricky. Remember that you're descoring on a trailer attached to one of your partners. They have a vested interest in not screwing you up. Also remember that a robot can not be forced into a penalty by an opposing robot. If an opponent is trying to stop you from descoring and this causes you to violate a rule, you shouldn't be penalized.
  #34   Spotlight this post!
Unread 06-01-2009, 11:33
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
True!
True!
True!
Not necessarily!
Yep! Here's an idea: try drawing the footprint within which you have to work (since that is your limitation), then include the portion of the trailer that you'd like to defend, then see if you can design a robot around what remains.
It's certainly possible. The only questions I have is;
1) Will FIRST allow a bot to goaltend in this way, and
2) Is incidental contact with the PVC bars of your own trailer (as in, not grappling or attaching to or climbing on, just occasionally touching or bouncing off with part of your robot) allowed?
I have to imagine #2 is going to be allowed, because there are going to be plenty of dumpers that engage in incidental contact when they pass balls into the opposing trailers. The real question is #1, because that's a conceptual question of how GDC wants this game to be played.
Also, where is everyone getting a 10" tongue from? Our mech team built one with a 14" trailer swearing it is correct from the drawings. Did they misread something?
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
  #35   Spotlight this post!
Unread 06-01-2009, 19:56
Eaglepilot52 Eaglepilot52 is offline
FRC #1591
Eaglepilot52 is just really niceEaglepilot52 is just really niceEaglepilot52 is just really niceEaglepilot52 is just really nice
Lightbulb Re: Defensive Strategies
An idea my team had that was initially a joke (and still kinda is) was the idea of camoflage. What the concept is is that the robot is built to look exactly like the trailer. That way, the other teams would not know the trailer from the robot. But what would be needed to fool the other teams is having multiple trailer/robots. Having one, you would still be able to distinguish the robot from the trailer.
This could turn out to be a good idea, mabye not.
My team is still in the designing stage.
  #36   Spotlight this post!
Unread 06-01-2009, 21:43
commodoredl commodoredl is offline
AKA: Dan Lavoie
FRC #2877 (LigerBots)
commodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud ofcommodoredl has much to be proud of
Actually that thought gives me an idea.
Looking through the manual, there are no rules against making your robot look like a field element.
I'm not thinking about the trailer though. I'm thinking about the foam cylinders on top marking alliances. Several teams, my own included, plan on using the camera to track and target other teams by their alliance indicators. Any teams who build their own dummy indicators would likely be able to fool most robots and mess with their targeting.
It would be very unGP to do something like this still. I will probably ask this in the Q&A because I wouldn't want to see teams doing something like this.
Technical Mentor
Team 2877 - Ligerbots
2016-
Previously:
Team 578 - Red Raider Robotics
2007-2014
  #37   Spotlight this post!
Unread 06-01-2009, 22:14
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I believe that <R2> makes that illegal
Originally Posted by <R02>
ROBOT parts shall not be made from hazardous materials, be unsafe, or cause an unsafe condition. Items specifically PROHIBITED from use on the ROBOT include:
A.
Shields, curtains, or any other devices or materials designed or used to obstruct or limit the vision of any PILOTS and/or COMMANDERS and/or interfere with their ability to safely control their ROBOT
B.
Speakers, sirens, air horns, or other audio devices that generate sound at a level sufficient to be a distraction or hindrance affecting the outcome of a MATCH
C.
Any devices or decorations specifically intended to jam or interfere with the remote sensing capabilities (including vision systems, acoustic range finders, sonars, infra-red proximity detectors, etc.) of another robot (i.e. changing ROBOT color to confuse opponent’s vision system)
D.
Lasers of any type
E.
Flammable gasses
F.
Any devices intended to produce flames or pyrotechnics
G.
Materials that off-gas noxious or toxic gasses
H.
Materials that produce hazardous inhalable particles
I.
Caustic chemicals
J.
Hydraulic fluids or hydraulic components
Teams should provide MSD Sheets for any materials they use that might be considered questionable during ROBOT inspection.
___________________
- Tennyson, Ulysses
  #38   Spotlight this post!
Unread 06-01-2009, 22:16
AKA: Dan Lavoie
Ah, you definitely got me there.
Back to reading the manual!
Technical Mentor
2016-
Previously:
2007-2014
defensive strategies Armando Rules/Strategy 74 14-04-2008 12:52
Defensive Strategies Goldeye Rules/Strategy 48 31-01-2006 19:16
YMTC: Defensive Strategies Matt Reiland You Make The Call 28 15-03-2005 15:11
Human player strategies? archiver 2001 6 24-06-2002 00:35
Best Strategies Rick Gibbs Regional Competitions 15 12-03-2002 09:23
