Go to Post Don't short change your drivers. They really need drive time. - Joe Johnson [more]
Unread 06-01-2009, 00:06
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
R08 Clarification
A.
BUMPERS must be built in segments, with a minimum length of six inches, and a maximum length that does not exceed the maximum horizontal dimension of the ROBOT.
Just for everyone trying to help, in the top right picture of page 10 of the robot manual, the bottom left bumper is one continuous piece curved around the corner.
Would the six inch minimum length be the entire bumper, so like 3 on one side 3 on the other, or 6 inches in each direction, so like 6 on one side 6 on the other? I'll probably post to Q&A, just checking CD's opinion
Unread 06-01-2009, 00:13
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: R08 Clarification
My opinion is that the total length of the curved bumper (the length if you flattened it out) must be 6 inches.
Unread 06-01-2009, 08:10
GaryVoshol's Avatar
Cogito ergo arbitro
My opinion is the exact opposite. The plywood cannot go around the corner. Bumper segments are defined to be 6" minimum, and bumper segments must be backed with plywood. The noodle going around the corner is extra.
(since 2004)
Unread 06-01-2009, 08:18
Any bumper that is segmented to fit your robot design must have a minimum segment length of six inches. "so like 3 on one side 3 on the other" does not fit the rule. The smallest segment in the referenced drawing is 6" and the section that appears to wrap around the corner consists of two backing boards, each longer than 6" with a continuous poll noodle and covering.
Unread 06-01-2009, 09:30
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Shall we take a look at Team 148's bumper set-up from last year, & the rules regarding bumpers that pertained to it for reference?
http://www.chiefdelphi.com/media/photos/30600
Unread 06-01-2009, 11:13
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
What if you took the plywood, wet it and let it dry in the curved form? Then it would be a single piece, not segmented. What would that do to the length requirement?
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
Unread 06-01-2009, 12:04
I am afraid 3/4" plywood doesn't take a bend very well even when wet.
Unread 06-01-2009, 13:17
GaryVoshol's Avatar
Cogito ergo arbitro
And the wood is not allowed to extend past the corner of the frame.
(since 2004)
Unread 06-01-2009, 14:52
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Where did you find this? The only part I see is <R08>N which says the "Hard" part may extend a maximum of one inch from the BUMPER PERIMETER. I don't see anything about corners.
Edit: Happy Birthday!
Hi!
Unread 06-01-2009, 16:23
Try the next paragraph.
Originally Posted by <R08>O
The BUMPER backing must not extend beyond the “edge” of the ROBOT. The backing of adjacent BUMPER segments must not attach to each other if the attachment would require that the joint extend into the corner (see Figure 8 – 4).
Unread 06-01-2009, 18:42
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
(thank you for the opportunity to recite the annual refrain...)
That would be a pretty silly thing to do, since (once again) RULES FROM PRIOR FRC GAMES DO NOT APPLY TO THIS YEAR.
If you have a question about the interpretation of the 2009 bumper rules, and if you are unable to discern the correct answer after an honest attempt to find it in The Manual, then I would recommend submitting a question to the official FIRST Q&A system after it opens up tomorrow afternoon.
-dave
Does <R08> prohibit above-bumper extension? BethMo Rules/Strategy 12 07-01-2009 09:20
IR Board Clarification Pavan Dave Rules/Strategy 3 06-01-2008 20:31
Clarification on Pinning Stu Bloom Rules/Strategy 2 15-03-2006 05:07
Rule <R08>, weight of upgrade parts Gary Dillard Rules/Strategy 6 11-02-2005 11:16
Rules Clarification archiver 2000 1 24-06-2002 00:28
