Go to Post Due to risk of unforseeable consequences, teams may not initiate a wormhole for the purpose of scoring ringers from past or future matches. - Richard Wallace [more]
Unread 06-01-2009, 12:24
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: ball cannon???
Originally Posted by Hachiban VIII View Post
I believe the reason why 1771 was able to create so much force was becuase they had an excellent seal on the ball.
F = P x A
So if you can gradually build up pressure over a large area you can create a lot of force.
But without a seal on the floor, it'll be pretty darn near impossible to build up pressure.
With a gap, F still = P x A, it is just much harder to get P very big. last year we were able to achieve a delta P of ~1 PSI, so with a 24" seal diameter, we had ~450 lb.s of force. With a 1/8" gap around a similar sized circle, you have a leak area of around 10 in^2 if you look at this as on orifice, it would equate to a diameter of ~3 1/2". if you can move enough air to get a pressure drop of 1/2 PSI, you have effectively added 225 lb.s to your bot. (not to mention the added benefit of the Bernoulli effect at the rim, very cool!)
You also now have 225 lbs of force trying to lift a .90" thick fiber panel from the floor. (have you ever seen an animation of "storm surge" in the eye of a hurricane?) I cannot imagine the rules committee allowing this.
Former Mentor Team 1771
Former mentor Team 4509
potato cannon northendchopper Chit-Chat 14 16-12-2009 12:19
Air Cannon Rob2713g General Forum 40 27-05-2009 21:15
WHere do you get Ball Casters/ BAll Transfers for FRC?!?!?!? leehyungjin4u General Forum 3 15-01-2008 23:27
air cannon Evil Asian General Forum 10 15-03-2007 10:31
Air Cannon Michael223 Technical Discussion 13 14-06-2006 10:23
