Go to Post Work hard. Then work even harder. Work until there is nothing left to work on, then work more. - RoboChair [more]
Unread 06-01-2009, 13:30
GaryVoshol's Avatar
Cogito ergo arbitro
BUMPER PERIMETER
I haven't seen this discussed much yet. This year we have a new definition, the BUMPER PERIMETER:
BUMPER PERIMETER – the polygon defined by the outer-most set of exterior vertices on the ROBOT (without the BUMPERS attached) that are within the BUMPER ZONE. To determine the BUMPER PERIMETER, wrap a piece of string around the ROBOT at the level of the BUMPER ZONE - the string describes this polygon. The BUMPER PERIMETER may extend up to, but cannot exceed, the maximum ROBOT volume constraints defined in Rule <R11>.
Then we have
Originally Posted by <R08>
K. BUMPERS must protect a minimum of 2/3 of the BUMPER PERIMETER. Teams are encouraged to maximize the area of the ROBOT protected by BUMPERS. But up to 1/3 of the BUMPER PERIMETER may be unprotected to provide flexibility in design options.
L. The BUMPERS must be fixed to the BUMPER PERIMETER.
Teams need to be very careful about how they design their frames. If you have concave sections of the frame, you cannot attach bumpers to that section. In the extreme, consider a robot frame in the shape of a Maltese Cross:
The Bumper Perimeter forms an octagon connecting all the vertices - and the frame touches the Perimeter only at those vertices. There would be no legal way to connect Bumpers to the Bumper Perimeter. Beware!
(since 2004)
Unread 06-01-2009, 13:40
Petey's Avatar
Petey Petey is offline
Strategy &amp; Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
Re: BUMPER PERIMETER
I saw this rule but I did not read this as a cannot. I just read it as a permissive rule--i.e., you can avoid putting bumpers on up to 1/3rd of your bot.
Suppose you had a chassis like this:
Are you saying that you cannot put bumpers on the inside (i.e. the concave) part of the chassis?
Or (and I do apologize for the crudeness of my drawings here),
You're saying that the bumpers in green are legal and the bumpers in red are illegal? Because the way I had read the rule was that the bumpers in green were necessary and legal but the bumpers in red were superfluous but legal.
Or am I misreading you entirely and you're simply making sure that teams know they need to protect 2/3rds NOT of the outside of their robot, but rather 2/3rds of the imaginary line described by the vertices of their robot?
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 06-01-2009, 13:57
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Bumpers on the inside are allowed, but will not count as standard bumpers, as they are not mounted to the BUMPER PERIMETER, and as such will not cover 2/3 of robot. Also not that you can't just attach the bumpers at the vertices and have them along the imaginary line that is the BUMPER PERIMETER, as they wouldn't be supported along the entire back side and violate letter M of the bumper rules.
Unread 06-01-2009, 14:06
Petey's Avatar
AKA: Chris Peterson
Does this mean that a trailer striking these bumpers would be in violation of the rule that it needs to hit bumper first?
In other words, if the rear of your robot is concave in the way I diagrammed above, and you kept the trailer nestled in close, would it be against regulations because the bumpers within the concave shape are not "real" bumpers because they lie within and not along the perimeter?
This seems like a very confusing rule!
Bio:
Unread 06-01-2009, 14:10
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Yes, which pretty much destroys any attempt to protect the trailer. Yay for offense!
Hi!
Unread 06-01-2009, 18:52
GaryVoshol's Avatar
Cogito ergo arbitro
The green bumpers in the above illustration could count as standard bumpers, with all the benefits and requirements of such: Not included in weight and size, must cover 2/3's of the Bumper Perimeter, etc. The red bumpers would not count as standard bumpers, and must be included in size and weight. Nor would they have to follow all the bumper build rules in <R08>. (Actually, a small corner of each red bumper is outside the bumper perimeter, and would have to be trimmed off.)
No, I don't believe so, as long as you're not talking about the trailer you're towing.
If the trailer you are talking about is the one attached to your bot, well Team Update 1 took that away from us. You can't attach the Trailer Hitch in the concave section of the illustration, between the red bumpers, because the Hitch has to be on the Bumper Perimeter.
(since 2004)
Unread 06-01-2009, 19:27
Petey's Avatar
AKA: Chris Peterson
That's what I was talking about; our original plan was to store the trailer nestled in that space to help stabilize its motion. But
Exactly.
Bio:
Unread 08-01-2009, 19:16
m^3's Avatar
m^3 m^3 is offline
AKA: M. M. M.
FRC #2040 (DERT)
m^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant futurem^3 has a brilliant future
Instead of a recess on the rear to help protect your trailer, what if you made a hexagonal cutout on the front that would that act as a guide to help your robot more accurately dump into an opponents trailer? Is this allowable? We couldn't find any specific rules against it... you aren't attaching to the trailer, only "fitting" up to it momentarily to dump your moonrocks. Bumpers could line the recess, but they wouldn't count as legal "bumpers" and lessen chances of inadvertant attachment or damage to the trailer. Does anyone know if this would be legal? There is a rule that robots must contact bumper to bumper, but what about the trailer?
Unread 08-01-2009, 19:31
GaryVoshol's Avatar
Cogito ergo arbitro
I don't see any problems with this, but you should check Q&A to be sure.
You still would not be allowed to contact the upper structure of the trailer, under the liberal <G29> interpretation found in Team Update 1.
(since 2004)
Unread 09-01-2009, 17:02
m^3's Avatar
m^3 m^3 is offline
AKA: M. M. M.
FRC #2040 (DERT)
Rules update 2 seems to confirm the legality of this, but they note that the bumper rules limit the size of the opening 26" centered on the front of a "wide" robot (minimum 6" bumper on each side of opening).
From update 2, section 8:
In the case of the archetype “wide drive” robot with a centered opening on the front of the robot, this can result in a significant limit on the size of the opening. This limits the ability for incursion inside the bumper perimeter by the trailer. See the example below.
Unread 12-01-2009, 11:03
Jared Russell's Avatar
Taking a year (mostly) off
There are still major interpretation issues that need to be addressed by the GDC ASAP.
Namely, the GDC wants us to only put bumpers on the BUMPER PERIMETER, and yet corners must be protected on both sides. This would preclude a LOT of the designs I have seen on Delphi this year.
Unread 12-01-2009, 11:48
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
They did address it, in their round-about way.
It appears that half of the robots in the game animation are illegal, because they don't have BUMPERS on both sides of every corner of the ROBOT PERIMETER.
Unread 12-01-2009, 12:04
tiger192 tiger192 is offline
FRC #2987
tiger192 is an unknown quantity at this point
Our team is having similiar problems with this rule. It seems that to comply with all the bumper rules AND the trailer tongue rule, pretty much the only shape the back end of a robot can be is square? What is the length of the trailer tongue that extends out of the trailer? The trailer BUMPER to BUMPER rule really limits the shape of the back end of the trailer.
Unread 12-01-2009, 12:27
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
The back does not need to be square
The back can bulge out, but not in.
___________________
- Tennyson, Ulysses
Unread 12-01-2009, 14:22
natraps117 natraps117 is offline
FRC #0573
natraps117 is an unknown quantity at this point
does anyone know if the space for the trailer hitch on the robot is included in the 2/3 required for the bumpers?
Bumper Qs Woody1458 General Forum 13 29-01-2009 16:41
bumper noodles lopz056 General Forum 3 24-01-2008 21:13
bumper coolguybigt Technical Discussion 4 27-02-2007 16:40
Bumper or No? WebWader125 Technical Discussion 19 11-01-2006 01:28
Bumper Sticker Carolyn Duncan Chit-Chat 14 11-07-2001 16:45
