Go to Post But FIRST isn't FRC anymore. We need to make way for FTC and FLL. - Tetraman [more]
Unread 06-01-2009, 15:10
Paul Rodi Paul Rodi is offline
FRC #0975
Paul Rodi is an unknown quantity at this point
PWM Cable
Hello,
My team and I are trying to figure out how to cut a PWM Cable? Can anybody help us, we tried using a zap cutter but it didn't work does anybody have any suggestions as to what we should use? We need the male end taken off completly, not the wires themselves. Has anybody had trouble with their male ends closing up? If so how did you fix it?
Team Synergy 975
Please and thank you
Unread 06-01-2009, 15:16
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Re: PWM Cable
Hey Paul,
Are you trying to just cut a PWM cable in half? Or are you trying to cut it and re-crimp the ends of a PWM cable to make it shorter?
We just use regular wire cutters or any "diagonal/side" cutters to cut our wires.
Unread 06-01-2009, 15:19
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: PWM Cable
I'm not sure if you're having trouble cutting through the 3 wires or making the modifications to the PWM cables provided in this year's kit but a simple pair of wire cutters should be able to do both of these tasks
Unread 06-01-2009, 15:27
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Re: PWM Cable
I would agree, wire cutters should work. In the past when we have cut PWM cables in half, a simple wire cutter did the job. And with the modifacations to the PWM cables this year, a basic pair of wire cutters should work. When we made the modifacations our pair of wire cutters did the job.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 06-01-2009, 15:28
#0368 (Kika Mana)
Re: PWM Cable
One suggestion that i've seen to take off the plastic that protects the male pins (other than to cut it off) is to stick a precision screwdriver between the plastic housing you want to take off and with some pressure it slides off.
Unread 06-01-2009, 15:37
FRC #0975
Re: PWM Cable
We are trying to get the end off as described in the update modification 1.
http://usfirst.org/uploadedFiles/Rel...ble%20Memo.pdf
whenever we tried using wire cutter but it compressed our pins together and almost ruined the wire. We can't figure out how to just cut the end like in the picture.
Unread 06-01-2009, 16:37
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: PWM Cable
You are probably using a wire cutter that is too big. Use a small flush cutter designed to cut 22AWG wire and smaller. I just cut up one corner and pulled them off. It worked fine.
Unread 06-01-2009, 19:20
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: PWM Cable
As already described in this thread, there is a simple technique for removing the pin hoods from the PWM wires that is very quick and (almost) foolproof.
Grip the pin hood with needle-nose pliers or a Leatherman tool. Position the width of the hood between the jaws, near the base of the jaws. When properly positioned, it will look like you are squeezing the three PWM wires in to each other if you were to apply too much pressure - this is the correct orientation. Squeeze slowly and firmly (do this very slowly at first, until you get a feel for the right amount of pressure). As pressure is applied, the rectangular pin hood will suddenly crease and deform into a semi-hexagonal shape. Stop squeezing. At this point the hood has released, and can be pulled straight off the end of the cable with your fingers.
It takes longer to describe the procedure than to do it. Once you get the hang of it, you can remove the pin hood and free the cable in about three seconds.
-dave
Unread 15-01-2009, 08:52
Randomness811 Randomness811 is offline
FRC #0178 (Team 178 The Enforcers)
Team Role: Electrical
Randomness811 is an unknown quantity at this point
Send a message via AIM to Randomness811 Send a message via Yahoo to Randomness811
Re: PWM Cable
Does anybody know where i can find crimpers for pwm cables?
Has anybody seen a set that will crimp an entire pwm, versus having to crimp each individual wire of the pwm?
Head of Electrical
Enforcers Team 178
Jesse G.
Head of Electrical
The Enforcers Team 178
Unread 15-01-2009, 10:53
Re: PWM Cable
Jameco has the crimper at: http://www.jameco.com/webapp/wcs/sto...gDrillDownView
Unread 15-01-2009, 11:10
Electrical1764's Avatar
Electrical1764 Electrical1764 is offline
Cambiano
FRC #1764
Electrical1764 is an unknown quantity at this point
Re: PWM Cable
Another technique I have used is hold the PWM by the wires fairly close to the end that is to be cut, and use a razor to cut the plastic off. This works very well, there is no need to squeeze anything and the end looks nice because it was not roughed up by a pair of wire cutters.
If You Can't take the heat, step away from the robot!!!
"You shut your mouth when you talk to me!"
Victor-PWM Cable connections RbtGal1351 Control System 17 24-02-2007 20:53
Victor and PWM Cable Problem RIgnazio Electrical 2 13-01-2005 23:02
PWM Cable Clip for Victors sanddrag Technical Discussion 9 18-07-2004 19:27
Female PWM cable connector Paul Marshall Technical Discussion 3 19-02-2004 12:10
