Go to Post If it gets people talking about not only robots but science and technology, it's all good. - Koko Ed [more]
Unread 06-01-2009, 18:58
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
Re: 4WD Turning Difficulties
Originally Posted by RoboGeek99 View Post
Were debating between 2 kinds of drive systems...tank style and car steering (back wheels are powered)...which do u think would be better on this lack of traction situation? (keeping the trailer in mind)
I really like the car style because it doesn't require you to whip around the trailer every time you turn. I also like that you can keep your wheels pointed (at least as close as possible) to the direction you want to move in. The only disadvantage I can see is the robot can't turn on a dime.
Also if you do the car style, make the turning wheels powered. It will be easier, maybe the only way, to turn in the direction you want, since the surface is so slick your unpowered turning wheels may have little effect.
IR Difficulties AmitCarmeli Programming 3 11-01-2008 20:49
Technical Difficulties muy dificil Programming 0 13-10-2005 11:25
Default Code Difficulties Drok00 Programming 3 02-02-2005 20:56
FIRST Technical Difficulties at Rutgers aka Scott White General Forum 10 27-03-2002 14:40
