Go to Post Look at the problem and find the simplest solution. Don't look at a solution and try to find a problem to solve with it. - apalrd [more]
Unread 06-01-2009, 19:16
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Team Update #1
Originally Posted by GaryVoshol View Post
So I guess the Trailer Hitch has to be designed to be easily removeable, huh?
I was hoping that FIRST was going to give the inspectors crowbars and reciprocating saws, in order to speed up the sizing of robots whose trailer hitches stick out too far.
Realistically, only if your robot is nearly 28 in wide, and has the trailer hitch on the 38 in side, will it have trouble fitting in the existing sizing boxes. Given that the materials required for the hitch are standardized, a standard weight could be deducted from robots weighed with a hitch. (I suppose that to use a standard weight like this, it would be prudent to specifically disallow modifications to the hitch design that would permit a small robot weight advantage to be gained by lightening it. On the other hand, it's the system weight that matters anyway, so it would only be a technical violation of the rules, rather than a meaningful one.)
Team Update #14 jgannon General Forum 11 05-03-2008 00:50
Team Update #18 Ben Piecuch General Forum 114 23-03-2007 17:52
Team update #11 Joe J. General Forum 74 23-02-2006 17:29
Team Update #3 dez250 General Forum 4 21-01-2004 11:56
Team Update #3 archiver 2001 0 23-06-2002 22:43
