Go to Post For me, FIRST is inspiration with a positive feedback loop - it just keeps getting better. I wonder where it will go from here... - petek [more]
Unread 06-01-2009, 17:22
EROCK EROCK is offline
FRC #2450
EROCK is an unknown quantity at this point
Blarg!
OK so I have been working on this project in lab view for several hours now all to know avail. I am trying to write a program so that when the trigger (button 1) is pushed, the robot will activate a spike in a forward or reverse direction. The spikes are wired to the digital side car under PWM 3 which is then connected into slot 4. did I wire the spike wrong? should it be wired into a relay connection? Any help would be necessary.
Unread 06-01-2009, 17:27
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Re: Blarg!
Yup, the spikes should be wired to the relay ports.
Only servos and speed controllers connect to the PWM ports.
Unread 06-01-2009, 19:38
FRC #2450
Re: Blarg!
would you might now how I would go about programming that in lab view? I already know that you must use the relay vi's but how might I tie that to a button? sorry but this is my first year coding
Unread 19-02-2010, 22:56
[TBT] Vampire's Avatar
[TBT] Vampire [TBT] Vampire is offline
Spartan-034
AKA: Dinkel
FRC #2865 (Roboteknix)
[TBT] Vampire is on a distinguished road
Send a message via MSN to [TBT] Vampire
Re: Blarg!
I loveeee Blargity Blarg-Tucker!
