DS Voltage reads 00.00V
Hey guys, just a question maybe somebody has some ideas why this is being difficult. Updated the cRIO to version 7 and the DS to the November update so we could set team number etc. We can't seem to get the voltage reader to register anything besides "00.00 V". The DS does indeed work, as we can control the motors with the Attack joystick. I poked around here for a while and didn't find anything. Any ideas?
Re: DS Voltage reads 00.00V
You need to install a jumper on two of the three stray pins on the analog bumper in the first module. You have a 50-50 chance of getting it the first time. If it still reads zero flip to the other two pins. I'm 100% sure it's in the manual somewhere.
Welcome to CD!
This question has been asked multiple times and answered both here and on FIRST Forums at forums.usfirst.com please search before you post. anyways you have to put a jumper on the analog break out on slot 1(closes to the Ethernet ports) on the cRio the jumper goes on the 3 pin connector separated from the rest of the connectors and th jumper connect the 2 pins closest to the outer edge of the cRio |
@both: Thanks, I'll look in the manual and give it a shot.
@0705920: Perhaps you didn't read my entire post, I did look all over this forum and couldn't find any solution, but thank you for pointing out that USFirst has its own forums. |
| pin voltage | tseres | Programming | 2 | 13-01-2008 14:30 |
| pic: Dez Reads HIGHLIGHTS! | Joe Matt | Chit-Chat | 8 | 26-05-2006 11:40 |
| OI Voltage | JAH | Electrical | 7 | 12-11-2004 20:01 |
| Who reads Slashdot? | Max Lobovsky | IT / Communications | 31 | 27-03-2004 00:07 |
| Voltage Byte -> True Voltage | Ulibrium | Technical Discussion | 11 | 01-03-2002 08:55 |
