Go to Post [the last period is] a free for all, both goals are turned on, and any robot can go anywhere on the field and score in any goal (although I would recommend scoring in the correct goal, not your opponents :D ) - Ryan Foley [more]
Unread 06-01-2009, 19:57
m3rc1l3ss m3rc1l3ss is offline
FRC #1178 (DURT)
m3rc1l3ss is an unknown quantity at this point
Re: Failed Benchtop test
Just wondering, does the motors turn when you push the joystick forward? The lights will always flash if there is currently no data going through the victor/jaguar, but they should turn to a solid red or green light when you move the joystick.
Unread 06-01-2009, 20:11
Bsteckler's Avatar
Bsteckler Bsteckler is offline
Resident computer tech
FRC #2402 (JamesMonroebotics)
Bsteckler has a spectacular aura aboutBsteckler has a spectacular aura about
We set ours up w/ victors and it works. You just need to know a bit more than the directions state when you do wifi.
"Don't try anything you are about to see us do at home, ever"
-The Mythbusters
2402 scores points.
Unread 07-01-2009, 06:34
rhoads2234's Avatar
rhoads2234 rhoads2234 is offline
AKA: Erin
FRC #2234
rhoads2234 will become famous soon enough
A good thought, but unfornutely, it doesn't work when the joysticks are pushed forward (or back.)
Also it is in Teleop, and We have tried reseating the PWMs.
ALWAYS a mechanical problem!
Unread 07-01-2009, 07:01
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
You would also see the light not come on if you don't have the dongle attached and the DS set to enable mode.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 07-01-2009, 11:06
rhoads2234's Avatar
AKA: Erin
FRC #2234
The dongle is in and it is set to enabled.
We are baffled by the problem.
Should we try to re-image the cRIO?
Unread 07-01-2009, 13:18
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
No don't think you're suppose to re-image the cRIO or update the driver station Firmware until after you have completed testing the hardware portion (what you are trying to do now), according to the benchtest manual.
Unread 07-01-2009, 16:06
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Are you sure you have the wiring in the correct direction? I believe the white wire on the PWM cable should face the inside of the digital side card and on the Victor the white wire should face towards the outside edge. Also make sure you have the digital side card plugged into the cRio via the digital expansion module closest to the network ports.
Unread 08-01-2009, 16:32
Christine2234 Christine2234 is offline
FRC #2234
Christine2234 is an unknown quantity at this point
Yeah, we've checked all our connections on the cRIO and the electrical board. So far, nothing has changed...
It seems one of the problems is that we can't see the cRIO on the laptop. We've connected the cRIO to the laptop with an Ethernet crossover. Although the laptop can see that something is plugged in, it cannot establish connectivity with the cRIO so we can't image it. We think this is the same problem as the DS being unable to enable to the cRIO...any thoughts?
Unread 08-01-2009, 17:37
I'll have Brian from 103 respond to this, if he's unable to figure it out, how far are you from their area?
Unread 08-01-2009, 17:45
awizkid awizkid is offline
JoJo
FRC #2063
awizkid is an unknown quantity at this point
Send a message via AIM to awizkid
does your digital sidecar have power? when we first set up ours we forgot to power it, without the digital sidecar being powered it cant recieve the signal from the module and can't sent out a pwm signal.
Unread 08-01-2009, 19:24
rhoads2234's Avatar
AKA: Erin
FRC #2234
Yes the digital sidecar has power, all three lights(5V,6V and the one that says BAT) come on. Every other indicator that the board has that is mentioned in the Benchtop test documentation comes on.
We think there may be something wrong with cRIO. We have tried using other crossover cables to see if the cable itself was the problem, but it still won't connect to anything.
Unread 08-01-2009, 22:08
Crossover cable? You should only use that to connect the camera to the cRIO's second ethernet port. All the other ethernet cables you use should be standard straight-through connections.
Unread 08-01-2009, 22:11
Delia's Avatar
Delia Delia is offline
FRC #1712 (Dawgma)
Delia is a splendid one to beholdDelia is a splendid one to beholdDelia is a splendid one to beholdDelia is a splendid one to beholdDelia is a splendid one to beholdDelia is a splendid one to beholdDelia is a splendid one to behold
Send a message via AIM to Delia
Hey Erin you should see if you guys can come to LM this saturday, our Lockheed guys can help you out.
Facebook me about it.
:: Delia ::
:: 2010 Dean's List Winner::
:: FRC 1712 Almuni::
Unread 09-01-2009, 16:00
FRC #2234
We've tried with straight up Ethernet cables, too, and still nothing.
We're located in Newtown Square, and I think that's around 2 hours from where 103 is...we might try calling an NI engineer and asking if it's a problem with the cRIO itself.
Unread 09-01-2009, 16:12
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
Please go ahead and contact NI through ni.com/first.
"Benchtop Test" Help! tiger192 Technical Discussion 5 07-01-2009 16:45
New Ctrl Sys Early Ship - Benchtop Test rrossbach FRC Control System 37 19-12-2008 00:40
Smithy or other Benchtop Mills/Lathes/CNC Dan Richardson Technical Discussion 6 21-06-2007 22:32
Compiling Failed Teh Mike Programming 7 09-02-2005 13:27
