Go to Post That's just the thing about plastic or brass gears; they tend to morph into plastic or brass washers real fast. - Nick Seidl [more]
Unread 06-01-2009, 20:02
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Re: Using Run in Labview
Originally Posted by BLAQmx View Post
The run button will run that VI and all subVIs called by that VI.
Just to clarify, are you saying it will run the teleop VI and all subVIs, but it will not run any VIs that are not subs, such as robot main, and any autonomous VI.
Using LabView to Teach Students.. Sykan NI LabVIEW 1 22-09-2008 12:14
Using the CMU cam in LabView VeedotJaydot Technical Discussion 1 10-09-2008 16:39
Students build SEGWAY in 3 months using Labview and the cRIO neutrino15 Programming 31 27-04-2008 22:08
Question about using labView in FRC itsme LabView and Data Acquisition 7 19-01-2007 15:22
Using the Example LabVIEW Apps Amin National Instruments LabVIEW and Data Acquisition 1 24-01-2006 08:51
