Go to Post What is this "tired" of which you speak? Did it come in the KOP? - EricH [more]
Unread 06-01-2009, 17:55
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Using Run in Labview
I haven't seen this come up yet...
When you click on the arrow to run your Labview program on the cRIO, does it matter which VI you have open when you click the RUN button? I've seen some of the framework manuals mention that you click RUN from the Robot Main.VI (in order to download that VI and all SubVIs) but does anyone know if it will still work if you click RUN from....the Teleop.VI? Or will only the Teleop.VI download and nothing else?
Unread 06-01-2009, 18:36
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
Re: Using Run in Labview
The run button will run that VI and all subVIs called by that VI.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Unread 06-01-2009, 19:20
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Since you need the communications to run, you need to always run the robotmain.vi
-Borna Emami
Team 0x27
Unread 06-01-2009, 20:02
#0368 (Kika Mana)
Just to clarify, are you saying it will run the teleop VI and all subVIs, but it will not run any VIs that are not subs, such as robot main, and any autonomous VI.
Unread 07-01-2009, 11:40
Correct. Like Borna said, since the driver station communication is handled in the Robot Main.vi, just running teleop itself won't work.
Unread 07-01-2009, 13:05
#0368 (Kika Mana)
Thanks Joe!
Using LabView to Teach Students.. Sykan NI LabVIEW 1 22-09-2008 12:14
Using the CMU cam in LabView VeedotJaydot Technical Discussion 1 10-09-2008 16:39
Students build SEGWAY in 3 months using Labview and the cRIO neutrino15 Programming 31 27-04-2008 22:08
Question about using labView in FRC itsme LabView and Data Acquisition 7 19-01-2007 15:22
Using the Example LabVIEW Apps Amin National Instruments LabVIEW and Data Acquisition 1 24-01-2006 08:51
