Go to Post w0000000000000t! - Andy Baker [more]
Unread 06-01-2009, 15:06
LoveMe_HateMe LoveMe_HateMe is offline
Ashley
FRC #1831
LoveMe_HateMe is an unknown quantity at this point
More Wheels?
Can you add a 5th moon wheel that would lower down and still be counted as one of the wheels to the bot and used as a break affect?
Unread 06-01-2009, 15:10
Re: More Wheels?
You can add as many wheels as you want as long as you follow the rules regarding how wheels are placed.
Rule <R06>
The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub).
Enjoy.
Unread 06-01-2009, 15:32
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Re: More Wheels?
And as long as it is the rover wheels, only the rover wheels can touch the floor surface this year.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 06-01-2009, 21:45
SWIM's Avatar
SWIM SWIM is offline
SomeoneWhoIsntMe
AKA: James Meintjes
SWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really nice
Re: More Wheels?
Although, if you expect physics to apply to your robot, you might as well lock up the wheels that already touch the ground, because dragging more locked wheels across the ground isn't going to do anything for you.
Unread 07-01-2009, 13:04
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: More Wheels?
In 2002, 624 made a robot with a 5th high traction wheel in the middle of the robot for pushing/shoving during the game. I don't have a picture of the robot but it was a beast. If anyone has a picture I would love to see that robot again!
I'm not sure that the 5th wheel will help you since you would be dividing your normal force by 5 wheels instead of 4 wheels.
A 5th wheel helps with traction when you have carpet but not with FRP !
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 07-01-2009, 13:36
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: More Wheels?
Actually Im not sure if thats true... Yes you would be dividing the normal force by 5 and thus the force of friction remains the same, but friction is not the only thing that needs to be considered. Traction would increase due to more surface area, and thus it would stop quicker.
Yes a 5th wheel is legal, and yes it would probably help a little. I would recomend if this would only be for breaking, mount it perpendicular to the other wheels rather than parallel. The coefficient of friction is higher for the wheels sliding laterally than in line with the rotation, so you would get more friction and stop even quicker.
Unread 07-01-2009, 13:41
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: More Wheels?
You don't really get any more traction with 5 vs. 4 wheels.
Surface area is not part of the equation.
From our friends at Wiki -
Maximizing multi-wheeled vehicle traction
It is important, due to broad application, to point out the specific case of multi-wheeled vehicles or vehicles with multiple contact patches between the tire and the road surface. Multiple wheels do not increase a vehicle's traction, because the friction force is independent of the contact area.[1] The friction force (Ff) is dependent upon the coefficinent of friction (COF) between the contact surfaces and the normal force (N = a force perpendicular to the contact surface).
Ff= N(COF)
A greater number of wheels will allow a vehicle to carry a larger load, thus increasing the resulting normal force. More traction is achived with a greater load because the potential frictional force has been increased.
The case of wheels sharing a given normal force is particularly important in vehicle design. Two identical tires sharing a common load achieve maximum stability when they share the load equally. Likewise, an unequally loaded pair of tires sharing a common load will not be able to achieve the same maximum stability.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 07-01-2009, 14:40
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: More Wheels?
To emphasize this, it's important to note the differences between this year and previous years. In the past, the wheels were slightly squishy, as was the carpet. As you powered your wheels, the carpet and wheels were able to conform a little, and provide a larger surface area and more grip do to the deformation in the parts. More wheels, therefore, would provide an increase in traction.
This year, the Regolith material is firm and slightly bumpy, while the wheels are firm as well. What this means is that each wheel is going to approximate a point contact with the surface, with no deformation of parts. the conditions the GDC has provided us as closely match the ideal friction equation posted above - where number of wheels does not change the robots traction (assuming all wheels are driven).
Unread 07-01-2009, 19:20
gamercards gamercards is offline
FRC #1728
gamercards is an unknown quantity at this point
Question Re: More Wheels?
What about have six wheels but only have four driving wheels? Will that have better traction?
Unread 07-01-2009, 19:40
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: More Wheels?
People will debate, and you won't get a straight answer most of the time. But, here is my take, more wheels doesn't matter (trust wikipedia).
This only applies if all the wheels are powered.
So, if you have two unpowered wheels, the weight on those wheels won't be providing extra traction to your drive train. So, as far as i know, power all the wheels that touch the floor.
my 2 cents
Unread 07-01-2009, 23:09
Ozeaden Ozeaden is offline
FRC #1388 (Eagle Robotics)
Ozeaden is an unknown quantity at this point
Re: More Wheels?
you wouldnt be able to have that wheel be a break because you would have to change something in the wheel so that you make it a break. it is against the rules to alter the wheels in any way.
http://www.eaglerobotics.com/
Unread 07-01-2009, 23:15
DonRotolo's Avatar
Back to humble
FRC #0832
Re: More Wheels?
The Q & A system has clarified the use of a sensor to detect motion, and it doesn't have to be a KoP wheel. See This.
I plan on dragging a (computer) mouse.
Unread 07-01-2009, 23:49
No Stolte No
AKA: Chris
Re: More Wheels?
No, you could just have it be rigid, or you could have the wheel turn in the oppisite direction. I don't see why you would need to alter the originality of the wheel.
Unread 08-01-2009, 03:06
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Re: More Wheels?
We added a 5th idler wheel today, but modified its position to not have any of the robot weight on it (ideally) to affect traction on the other 4 driven wheels. We started testing and should be able to report on our website in a few days.
Unread 08-01-2009, 21:06
omgeezly21 omgeezly21 is offline
FRC #1293
omgeezly21 is an unknown quantity at this point
Re: More Wheels?
Has anyone ever added a retractable wheel and gotten it to work? I'm not sure if thats what one of you were suggesting up top but we were thinking about trying to add a retractable wheel but we didnt know exactly how we should approach it...any ideas?
Has Being In FIRST Made You More Brave - More Confident? JaneYoung General Forum 25 08-05-2007 10:11
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Image Discuss: Wheels- you want wheels - more from team 25 CD47-Bot Extra Discussion 10 07-09-2003 20:33
More Wheelchair Wheels archiver 2001 0 23-06-2002 23:15
More Wheelchair Wheels archiver 2001 1 23-06-2002 23:15
