Go to Post "If you can't hurdle, you can't win." "Remember to practice your obnoxious amateurism." . - dlavery [more]
Unread 05-01-2009, 16:52
ROFLcopter's Avatar
ROFLcopter ROFLcopter is offline
who was phone
AKA: Robert Grizzell
FRC #2364 (Oregon RoboHawks)
ROFLcopter is on a distinguished road
Send a message via AIM to ROFLcopter Send a message via MSN to ROFLcopter Send a message via Yahoo to ROFLcopter
Trailer Specs
As most of you have already figured out, the specs for the trailer that FIRST gives you isn't very user friendly. If anyone has translations that would make it easy to build a mock-up trailer for 1st and 2nd year to build, that would be nice.
Currently we only need the base.
This signature has been removed in accordance with City Ordnance law L34.B3. If you feel this signature has been mistakenly removed for reasons not within the guidelines of L34.B3. Visit the City Courthouse #3 and file a report.
Unread 05-01-2009, 17:58
neoshaakti's Avatar
neoshaakti neoshaakti is offline
FRC #2554 (WarHawks)
neoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to beholdneoshaakti is a splendid one to behold
Send a message via AIM to neoshaakti
Re: Trailer Specs
we're going to attempt to decipher the assembly tonight
I'll let you know how that goes, and send u some dimensions and anything else that can make it a little easier to understand within a day or two
good luck
Unread 05-01-2009, 18:52
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
Re: Trailer Specs
We simultaneously found with a TI-83 and a mock up in sketchup that the length of the hexagon's sides are 16 3/16" long, and that's all we got today.
Hope that little bit helps.
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 05-01-2009, 19:01
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: Trailer Specs
Look at this thread.
It should help
Former Mentor Team 1771
Former mentor Team 4509
Unread 06-01-2009, 21:23
rilesmitch's Avatar
rilesmitch rilesmitch is offline
main programer
AKA: mitch
FRC #2364 (robohawks)
Team Role: RoboCoach
rilesmitch is an unknown quantity at this point
Re: Trailer Specs
It sounds like most of you are finding the trailer specs as confusing and misleading as we did. So here is what I have found so far......
First, go to: Competition Manual
Then go to: Official FIRST Drawings
And then to: 2009 Game Specific Drawings
This will take you to a set of drawings for the trailer, it's parts, the outpost, etc... Once you are there you have to hunt for the drawing you want. To find the trailer size, etc. Look at drawing: GE-09002 You will have to do a liitle math in order to find out that the trailer is 28.5" wide. But I've noticed some comments that this is the overall width. NOT TRUE! This is the trailer with NO bumpers.
So, I wanted to know the size of their bumpers..... I looked at multiple drawings, did some math, made a few scaled drawings, and wal-la! Their bumpers are.... well, that depends on how you inturpet them. Bottom line is, you need to ad 3" for each side (bumpers) Total trailer width is 34.5"
However, if you look closely, and build the trailer and bumpers to their spec's you will find that you can't bolt the bumpers to the trailer. The holes will 1/8" off. Their math, drawings, or dimensioning is incorrect.
Sounds like a normal day of trying to put 10 gallon in a 5 gallon bucket!
Unread 06-01-2009, 21:26
AKA: Richard Raitt
FRC #1793 (Pilots)
Re: Trailer Specs
28.5" is the trailer platforms with the 1/4" plywood on either side.
______
Unread 06-01-2009, 21:36
rilesmitch's Avatar
main programer
AKA: mitch
Re: Trailer Specs
Sorry if I'm wrong. But, what 1/4" plywood? There is a top plate, bottom plate, spacers, and the bumpers bolt directly to this. The bumper backing "plate" is 3/8" white coroplast material (not plywood) and the noodle is 2.5".
Correct me if I am wrong.... I am seeking the truth as well.
I need a bigger bucket!
Unread 06-01-2009, 21:49
martin417's Avatar
AKA: Martin Wilson
Re: Trailer Specs
You are looking at draawings that begin GE-9... these are official game pieces. You probably do not want to build tho$e.
Look at the team field drawings. These drawing names begin with TE... They use 1/4" plywood instead of alumalite, 1/2" plywood for the bumper backing, and many other cost saving measures.
They are also wrong. In several places. The wheel axle bolts are at least 1" too short, they don't use enough screws to hold it together, and the drawings use ordinate dimensioning, which can be confusing. If you read this thread it should help decipher them
Hope this helps,
Martin
Unread 06-01-2009, 21:51
nahstobor's Avatar
nahstobor nahstobor is offline
EWCP
AKA: Shan (pronounced Shawn)
FRC #2733 (Pigmice), FRC #612 (Chantilly Robotics)
nahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond reputenahstobor has a reputation beyond repute
Re: Trailer Specs
Has anyone created a CAD model of the trailer?
Unread 06-01-2009, 21:52
AKA: Richard Raitt
FRC #1793 (Pilots)
Re: Trailer Specs
About 95% sure on this:
On the team drawings, the spacers are connected to 1/4" plywood, and the noodles are wrapped to that. But thats nitpicking, really. What really matters more is that the centers of the pipes are on a 25" diameter circle, not the tiny space outside the pipes. My team decided that we won't even bother with the noodles, they don't effect the driving that much, for us anyway.
______
Unread 06-01-2009, 21:56
rilesmitch's Avatar
main programer
AKA: mitch
Re: Trailer Specs
AaaahhhGG !!!
Are you kidding? If the drawings are not correct they shouldn't even be on the site! We should have ONLY the drawings that actually help us. And if there is a revision, the old drawing should be disguarded. I only wasted one day on this!
Thanks for the help, hope I can return the favor soon.
Has anyone seen a bucket?
Unread 06-01-2009, 22:00
rilesmitch's Avatar
main programer
AKA: mitch
Re: Trailer Specs
I understand it's being nitpicky. But the whole point was to find out the actual size of the trailer and the distance from the outside edge of the bumper to the pipes.
Thanks all.... I'm sure we can get it right if we keep digging and working together.
I'm about to kick the bucket!
Unread 06-01-2009, 22:14
notaPINKtruck's Avatar
notaPINKtruck notaPINKtruck is offline
AKA: Ryan Julian
FRC #0233 (The Pink Team)
notaPINKtruck is a splendid one to beholdnotaPINKtruck is a splendid one to beholdnotaPINKtruck is a splendid one to beholdnotaPINKtruck is a splendid one to beholdnotaPINKtruck is a splendid one to beholdnotaPINKtruck is a splendid one to beholdnotaPINKtruck is a splendid one to behold
Send a message via AIM to notaPINKtruck
Re: Trailer Specs
I'm definitely not impressed with the trailer instructions. I just spent and entire day building one and will continue tomorrow morning.
For one you're right, dimensioning is off in a lot of places. For instance: they assume a 2X4 is actually 2" x 4", which has to be the rookiest mistake in carpentry.
Also, there's no way that just luan + plywood sides is going to withstand a whole season's worth of practice. It could serve as a nice ornament but it can't take any kind of beating. They have all the weight resting on flimsy pieces of luan siding (including the wheel wells and very heavy center pipe). I'm going to add 2X4 standoffs in the center of ours to at least give it a chance of surviving until April.
Another thing is that all of the dimensions are very odd such as 57 1/4" or 42 7/8", which tells me someone designed it in CAD and never actually tried building it. No carpenter would sweat 42 7/8" vs 43" on a project like this (mayhaps a cabinet maker).
Rockledge HS/Cocoa Beach HS & NASA Kennedy Space Center
Team 233: "The PINK Team"
Unread 06-01-2009, 22:53
AKA: Richard Raitt
FRC #1793 (Pilots)
Re: Trailer Specs
...and the distance from the outside edge of the bumper to the pipes.
make a compass out of a scrap piece
in other words,
1. find the center of the hexagon
2. take a thin (<1/2") piece of scrap ply, board, lexan, whatever, about a foot and a half long.
3. measure a tiny amount under 12 1/2" apart on the scrap, drill the holes with ~1/4" bit.
4. with a pointy thing (awl, something in a multitool, you get the idea), hold the tip through a hole on the center of the hexagon.
5. using a pencil, draw a circle through the other hole you drilled.
6. go to the schools drafting class, geometry guru, or somebody that has 45 and 30/60 triangles. Bum one of each off them. Nicely, of course.
7. try different combinations of the two triangles to achieve a 15 degree angle from the center, from the opposing corners. Continue the line to the corners of the hexagon.
8. continue by using the 30/60 triangle to add 30 degrees to the line FROM THE CENTER, making sure to mark where these 'spokes' intersect the circle.
9. once you have all 12 intersections clearly marked, use a 1 1/4" hole saw or spade bit to drill the holes. (if you can, use the spade bit in the drill press)(you will probably have to file the holes out afterward)
9 1/5. if you want to drill through both hexagons, line up the edges and clamp them together and do them both at once.
10. admire your work.
NOTE: the spade bit can kick like a mofo. be careful and have someone watching/ holding the hexagons with gloves
______
Last edited by NorviewsVeteran : 06-01-2009 at 22:56. Reason: increased grammatical clarity
Trailer Weight Seat Ninja General Forum 19 29-01-2009 20:29
trailer dimensions mackfix General Forum 2 03-01-2009 20:21
Trailer Cover? darkpheonix Rules/Strategy 1 03-01-2009 19:46
Halo 3 Trailer bestvids Chit-Chat 5 29-11-2006 11:44
To Trailer or Not to Trailer? Carol General Forum 14 25-06-2006 18:14
