Go to Post I firmly believe that it's within your power to aspire instead of lament. - Alan Anderson [more]
Unread 06-01-2009, 21:43
Bob Guetzlaff Bob Guetzlaff is offline
Battery Guy
FRC #0525 (Swartdogs)
Bob Guetzlaff is an unknown quantity at this point
DS Power supply voltage
Has any teams checked the voltage comming out of the power supply? its rated at 12 volts but we got 19.7.
Unread 06-01-2009, 22:04
Re: DS Power supply voltage
16.44v
Unread 07-01-2009, 08:23
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
It may not be a regulated supply (which typically also means that it needs to be loaded in order to produce the "proper" voltage). Are you measuring the output when it's connected to the DS?
Russ
Power Supply evit General Forum 2 06-02-2003 08:59
