Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
  #151   Spotlight this post!
Unread 06-01-2009, 19:47
Eaglepilot52 Eaglepilot52 is offline
FRC #1591
Eaglepilot52 is just really niceEaglepilot52 is just really niceEaglepilot52 is just really niceEaglepilot52 is just really nice
Re: How can we drive on this new floor?
How to drive on the new arena surface? Well, stated in the rules, ALL robots have the exact same wheels. They cannot be modified. So I guess to drive well, you need a good driver, a good robot design, and some luck.
However, I heard that having less wheels would be better. I think mabye it's becuse there's less traction or something like that...
  #152   Spotlight this post!
Unread 06-01-2009, 21:40
JagWire's Avatar
JagWire JagWire is offline
Team 1742 College Mentor
AKA: Tim Long
FRC #1742 (Shockwave)
JagWire has a spectacular aura aboutJagWire has a spectacular aura about
Send a message via AIM to JagWire
Originally Posted by Hachiban VIII View Post
"Long" drive configuration with a wheel at each corner. Normal tank-steering.
Geared for around 8 fps.
Weight makes a HUGE difference.
Also realize that other bots won't be able to push you as hard as you can kick.
Crashes are a different story.
Were the wheels maintaining a 'static' state? or were they spinning a lot?
Hehe, sorry for asking so many questions. I'm interested in the first-hand experience. My team hasn't gotten their hands on the regolith flooring yet, and are considering a 4-wheel tank drive. we're considering a wide frontal orientation for the wheels though. so the front of the bot would be the longest side. we'll see if this helps improve turning ability. I think we're going to be up for a LOT of testing (trial and error) this year. haha.
Team 1742: Shockwave
2006 Robot "Sprocket"
2007 Robot "Rampzilla"
2008 Robot "Trigonosaurus"
Aut viam inveniam aut faciam.
I'll either find a way or make one.
www.team1742.com
  #153   Spotlight this post!
Unread 06-01-2009, 22:13
ezygmont708's Avatar
ezygmont708 ezygmont708 is offline
FAIL = First Attempt In Learning
AKA: Zygmont
FRC #0708 (Hatters Robotics)
ezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant futureezygmont708 has a brilliant future
We have a tank drive that we use each year for prototyping. Please take a look at the video on the link below...
http://www.youtube.com/watch?v=s1Rl8mcTpjw
This is just last year's code running two CIMs per toughbox. Just a little video taste....
E. Zygmont
Team Lead - Team 708 Hatters Robotics
Hatboro- Horsham Senior High School - Horsham, PA
  #154   Spotlight this post!
Unread 06-01-2009, 22:31
swamp_child's Avatar
swamp_child swamp_child is offline
AKA: Cody
FRC #0179 (Children Of The Swamp)
swamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to all
Originally Posted by DanDon View Post
A holonomic drivebase would still be possible even with just the KOP wheels. The coefficient of friction is low enough that a swerve base or kiwi drive would both be possible, since the wheels slide easily enough.
Kiwi doesnt quite work, because the coefficient of friction when moving laterally is far greater than that of when the wheel is moving normally.
2009 Florida Champions thanks to 233 and 1649!
2008 UCF finalists thanks to 69 and 342
2007 world Finalist, thanks to 233 and 71, we love you guys
2007 Archemedies undefeated champions, thanks to 233 and 71
2007 UCF finalists thanks to 1902 108 and 386
  #155   Spotlight this post!
Unread 06-01-2009, 23:04
RoboGeek99's Avatar
RoboGeek99 RoboGeek99 is offline
FRC #2582 (Panther Bots)
RoboGeek99 is just really niceRoboGeek99 is just really niceRoboGeek99 is just really niceRoboGeek99 is just really nice
What looks like could be a problem with that is the trailer is going to jacknife and that could make a huge diference
"Imagination is more important than Knowledge"-Albert Einstein
Love, Peace, and Robot Grease
2008-Lone Star Regional-Rookie Inspiration Award
2008-Lone Star Regional-2nd Place Winners w/ 118 Robonauts & 501 Power Knights
  #156   Spotlight this post!
Unread 06-01-2009, 23:16
pacoliketaco's Avatar
pacoliketaco pacoliketaco is offline
Alumni
FRC #1807 (Redbird Robotics)
pacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to beholdpacoliketaco is a splendid one to behold
Send a message via AIM to pacoliketaco Send a message via Yahoo to pacoliketaco
although my team has already bought some of the flooring, we have yet to test it out. hopefully soon we will be able to retrofit an old robot to make use of the new wheels. i think that practice is really going to make a difference this year.
on a separate note, ive read a lot of posts about driving this year, but no one yet (as i have seen) has brought this up:
from rule regarding wheels (i dont remember the number)
...a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub)...
if you ask me, we dont have to have the wheels spinning in a circular orbit. by building a hub that allows the rotation of the wheel to be offset from the center, a different driving stlye would result. im not sure if this would help at all, or be legal for that matter, it just seemed interesting.
Pace Nalbone
Carnegie Mellon University
Mechanical Engineering Class of 2013
2009 NYC Winner - 56 and 1796
(2009 Regional Record: 18-0-7 wins/ties/losses)
  #157   Spotlight this post!
Unread 06-01-2009, 23:53
run the trap!!!
Team Role: Human Player
It didn't drive so well once we got the trailer going today
Our driver did develop a clever method of jack-knifing the bot back and forth to turn around. Simply tank steering was impossible with the trailer...
We're looking into the wide config also... Let me know how it goes for you.
-Philip J. Fry
  #158   Spotlight this post!
Unread 07-01-2009, 08:57
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
<R18> part b
The Trailer Hitch must be rigidly attached to a fixed location on the ROBOT, with the long dimension of the Trailer Hitch horizontal and the opening of the C-channel facing away from the ROBOT. The horizontal center line of the Trailer Hitch must be 2-13/16 inches above
the floor.
this may inhibit wide robots but im not sure?
  #159   Spotlight this post!
Unread 07-01-2009, 09:11
chuckmerja chuckmerja is offline
FRC #1696 (RoboRevolution)
chuckmerja is an unknown quantity at this point
Team 1696 "driving" last year's bot with new wheels on FRP - ufduh!
http://www.youtube.com/watch?v=Zc_L3Cbz5nQ
http://www.youtube.com/watch?v=WbG5Ft72z9I
2005 - Sacto quarterfinalist
2006 - Sil Valley quarterfinalist
2007 - AZ semifinalist, 2 judges awards, Woodie Flowers Award
2008 - smallest team from smallest school in FIRST - 3 person team!! - Seattle semifinalist
2009 - let's just say this bot would not have qualified for a trip to Mars
2010 - redoubled quality effort - won quality award and WINNER Utah Regional (first MT team to win an FRC regional) also won state FTC tourney (team 724)
2011 - Finalist UTAH regional
  #160   Spotlight this post!
Unread 07-01-2009, 11:02
dudefromjapan dudefromjapan is offline
Driver/Electrical Team
FRC #2496 (Team TruBlu)
Team Role: Electrical
dudefromjapan is on a distinguished road
We got a 4 wheeler running on the game floor today with the wheels.
Seemed to be controlable enough. We could turn it when it weighed 30 lbs. and when it weighed 120~160 lbs. it turned even better.
We'll have to see how it goes with the trailer.
How's the acceleration and breaking on it?
  #161   Spotlight this post!
Unread 07-01-2009, 12:03
Boco Gear Boco Gear is offline
AKA: Brad Vanderhoef
FRC #0263 (Aftershock)
Team Role: Student
Boco Gear is an unknown quantity at this point
Send a message via AIM to Boco Gear Send a message via MSN to Boco Gear
Wow there are a lot of ideas being thrown out here. I have to see in all of them games I have seen for FRC this is definitely something new. As for driving on this new surface it seems hard.
JUst wondering wouldn't the drifting ideas and driving on ice ideas kind of be hindered from the trailer a bit?
  #162   Spotlight this post!
Unread 07-01-2009, 13:59
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Does anyone have any idea why WildStangs removed their driving video from youtube?
  #163   Spotlight this post!
Unread 07-01-2009, 14:29
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Probably one of their team members put it up without asking the team and then the rest of the team asked that member to remove it.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
  #164   Spotlight this post!
Unread 07-01-2009, 14:55
jager1976 jager1976 is offline
FRC #2143
jager1976 is an unknown quantity at this point
Originally Posted by Thermal View Post
There is another rule stating that the wheel's rotation MUST BE inline with movement of the bot, so that the axle the wheel is on is perpendicular to the bot and wheels movement
I'd be interested in where this rule is. <R06> says "The ROVER WHEELS must be used in a “normal” orientation (i.e. with the tread of the wheel in contact with the ground, with the axis of rotation parallel to the ground and penetrating the wheel hub). The ground being a plane, this seems to suggest that the wheels may be angled. Maybe?
  #165   Spotlight this post!
Unread 08-01-2009, 01:25
FatBabyJezus's Avatar
FatBabyJezus FatBabyJezus is offline
IczyG
FRC #2204
Team Role: Webmaster
FatBabyJezus is on a distinguished road
would car steering be a bad idea?
EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? mayazk Programming 2 16-02-2008 02:17
New skateboard... Just imagine the robotics drive applications this would create Elgin Clock Technical Discussion 8 21-07-2007 12:56
How can this be!?! Mike Rush Math and Science 6 09-12-2004 13:51
How many drive motors did you use (per side) this year? Billfred Motors 19 16-10-2004 20:27
How can we make this better? archiver 1999 6 23-06-2002 22:39
