Go to Post You're not on your own, use your team members. They are the most valuable source of ideas that you have. - fr05ty27355 [more]
Unread 06-01-2009, 23:39
Pneumaticsman's Avatar
Pneumaticsman Pneumaticsman is offline
AKA: Mitch guzman
FRC #1566 (Ammoknights)
Pneumaticsman will become famous soon enoughPneumaticsman will become famous soon enough
Send a message via MSN to Pneumaticsman
Question WIPILib vs. LabView?
hey which program do you guys think would be better to program the robot with this year? I was just wondering this cause I'm kinda curious if you guys know if one is better than the other
Thanks
be prepared for the unexpected
Unread 07-01-2009, 11:29
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
Re: WIPILib vs. LabView?
I myself am more comfortable with C++ and I think it will offer greater flexibility and more complicated algorithms. That being said LabView is supposed to be nice and easy if your not doing anything to complicated. I would go with C++ (and I am).
Unread 07-01-2009, 12:11
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
I sort-of tried to address this question briefly in another thread:
http://www.chiefdelphi.com/forums/sh...8&postcount=14
Basically, they are both equally capable programming languages. Some people prefer C++ because procedural programming is more familiar to them. Don't dismiss LabVIEW as a toy-language just because it's "programmed visually".
Personally, I'm going with LabVIEW since it tends to be more syntactically forgiving and more intuitive (and hopefully easier to teach).
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 07-01-2009, 12:37
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
Our team is using Labview this year. After thinking about it, we decided this because we wanted to minimize the how much coding we had to do in the long run. Basically more time in front of the whiteboard solving problems and less time on the computer implementing the solution. We believe after learning Labview's all-in-all flow of things, it will in enable this.
Unread 07-01-2009, 13:01
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Labview.
We wanted to try something new - and labview allows C programming inside boxes (after a fashion) if you want to do something really fancy that labview doesn't support easily or natively.
Unread 07-01-2009, 14:13
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
labview's paradigm of implicit parallelism (and dataflow) had me sold the moment i tried it out. Its fascinating when you can just draw two loops next to each other and know that they both execute at the same time!
labview's ability to create clusters and pseudo-datatypes on the fly is also very nice, and the ability to look at a diagram and see what its doing without too much hassle is also a plus.
i beleive the perfect control system is a combination between labview and c++, considering you can do library calls within labview to DLLs compiled in c++ (or other languages)
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 07-01-2009, 15:35
kyungjin kyungjin is offline
Software Specialist
AKA: Daniel
VRC #0646
kyungjin is an unknown quantity at this point
Send a message via AIM to kyungjin Send a message via MSN to kyungjin
I'm going with WindRiver C++ cause text seems to make a lot more sense than all these different color shapes and boxes that seem to confuse me even more...
Also, I guess cause I'm more comfortable with C++, it's a no brainer for me... The problem though is... getting used to WPILib Robotics Library and it's functions and classes... ugh...
Labview Servos quizbiz NI LabVIEW 5 09-01-2009 08:48
LabVIEW vs C/C++ 3DWolf Programming 11 05-12-2008 09:14
learning LabVIEW Lions for First National Instruments LabVIEW and Data Acquisition 11 21-04-2008 15:26
Labview tseres Programming 2 23-05-2007 00:27
Labview Phreakuency LabView and Data Acquisition 6 14-01-2006 01:14
