Go to Post Your iphone may be more intuitive for some of your students than a screw driver. - Isaac501 [more]
Unread 07-01-2009, 00:01
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: detecting your own alliance(C++)
Originally Posted by daltore View Post
Basically, constructor is the equivalent of Initialize() or IO_Initialization() of the PIC version of WPILib, except I think it runs more than once.
A constructor is a standard C++ language feature, and constructor only gets called once per created object, and only when the object is instantiated (for example, if you do a "new ObjectName()" then a new object is created and a constructor is called.. of course there are other ways to create an object also).
If you examine WPILib, the START_ROBOT_CLASS macro passes startRobotTask() a function that creates an object of your RobotBase derived class. Once it starts the robot task, it creates your object. This is only done once (or at least, only when FRC_UserProgram_StartupLibraryInit() is called).
Strictly speaking, FRC_UserProgram_StartupLibraryInit (also defined in the START_ROBOT_CLASS macro) is more like Initialize() or IO_Initialization()... but of course it gets called before your task is created and its probably not a particularly great idea to use it.
Make your own CNC whytheheckme Technical Discussion 8 25-07-2007 02:13
Your Own Team Siggies Cujo General Forum 8 26-02-2005 16:01
any of your regional "buddies" with your in your alliance? Alex Cormier Championship Event 12 08-04-2004 04:20
How do you tell whether your sensor is detecting a crate or the diamond plate? Greg Ross Technical Discussion 4 13-01-2003 19:02
Making your own gearbox? ChaosMonkey Motors 15 25-05-2002 11:07
