Go to Post There's a fine line between cockiness and confidence. Confidence is one of the major keys to success and happiness in life. As long as one can carefully stay on the right side of the line, staying connfident while remaining humble, and ego can be quite beneficial. - Karthik [more]
Unread 06-01-2009, 22:01
steadfasttuna steadfasttuna is offline
AKA: Hamzah
FRC #2468 (Chap Robotics)
steadfasttuna is a glorious beacon of lightsteadfasttuna is a glorious beacon of lightsteadfasttuna is a glorious beacon of lightsteadfasttuna is a glorious beacon of lightsteadfasttuna is a glorious beacon of light
Where to buy a 'Robot sized' CV Joint
I have been looking for a CV joint to use on our robot. I cant seem to find one online that is small enough to use on our robot.
Thanks,
Hamzah
Unread 06-01-2009, 22:16
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Where to buy a 'Robot sized' CV Joint
There is a simple type used on some radio control cars, that is sort of like a "dog bone".
The end fits into a socket that just has a hole drilled in it, and a slot cut across it.
You might be able to make this if you have a lathe and drill press.
Unread 06-01-2009, 22:57
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Not CV joints, but this may work for ya
http://www.sdp-si.com/web/html/univjoints.htm
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 06-01-2009, 23:03
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
You do not need to use an expensive CV joint.
You can just use two simple Universal Joints in Series (each bent at the same angle) to create a CV joint.
This is called a DOUBLE CARDIAN joint.
If you do not use two, it will not be a constant output velocity.
Hope this helps!
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 06-01-2009, 23:13
SWIM's Avatar
SWIM SWIM is offline
SomeoneWhoIsntMe
AKA: James Meintjes
SWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really nice
Another related issue...
Where can you buy a robot sized differential? Preferably limited slip or locking...
Unread 06-01-2009, 23:58
Dick Linn's Avatar
no team (Synergy)
Hey, Gabe, how you doing?
Funny thing about some of those joints, about the velocity and so forth. Tricky stuff it can be - not always apparent.
You doing OK? Congrats on the climbing "noodle" 'bot there.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 07-01-2009, 00:14
Devo1098 Devo1098 is offline
FRC #1098
Devo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really niceDevo1098 is just really nice
CVD's and differentials?
sounds like a 4wd Ackerman steering bot to me....
with the low traction you really don't need either. just let one slip, i even like how a solid axle handles (rc car racer)
instead of cvd's i thought of using a flex shaft, honestly, with the almost no traction your not gonna be able to put down any power, so in this situation, you could get away with it.
you can call me a idiot for cheating the differentials and constant velocity shafts, but your not trying to make it last thousands of miles before a tire change, and the low friction even helps this fact.
Unread 07-01-2009, 08:38
ggoldman's Avatar
FRC #0401
My research focuses a lot on the properties of universal joints, so I know all about how they work (even the non-apparent properties)
I am doing fairly well, and the press on my robot has been crazy...have an interview with Popular Mechanics today, we will be in Pop. Sci and Inc magazine soon. Been keeping my hands full working with team 401.
How have you been doing? (Might be best to send me a PM back)
Best,
-Gabe
Gabriel Goldman
PhD Candidate
Virginia Tech
Unread 07-01-2009, 08:46
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Thanks,
Hamzah
Can you describe the application a bit more? Something as simple as a bellows joint or spider coupling may be sufficient. Torque? Application?
Unread 07-01-2009, 15:44
AKA: Hamzah
We are trying to steer powered wheels and we need the shaft to be able to have a bend in it and still transfer power. I first was looking for a U joint but one of our mentors said that it would not give us a constant power, in other words it would be 'jerky'.
Unread 07-01-2009, 16:00
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
For this year, you could probably get by with RC Monster Truck 4x4 front end units. Any good RC place should have the right stuff.
Typically for FRC robots teams build steerable pods (see swerve drive, or crab drive threads).
Teams with (in my opinion) excellent crab drive modules to benchmark would be 111, 496, 71... And many others. With the low torque and low skid traction this year, it might be a good year to try making a Crab drive module as typical failure modes should be less due to the lower loads.
Where to buy Buy FRP in AZ? falconmaster General Forum 9 05-01-2009 16:36
Where to buy x???? FIRST JerseyKid Technical Discussion 10 23-05-2007 23:52
Where to buy motors. bilal1219 Electrical 1 21-02-2007 22:23
Where to buy T fittings? jgannon Pneumatics 4 22-01-2007 17:24
where to buy! Ben Mitchell General Forum 2 20-01-2002 23:14
