Go to Post Every year, 118 inspires our team to dream for the stars, and land on mars. If 118 wasn't there we wouldn't be off the ground. Think about it every superstar has critics. Keep doing what you do 118. - xSAWxBLADEx [more]
Unread 07-01-2009, 00:43
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Re: pic: Legal Bumper Configuration?
This isn't legal, part I of rule <R08> requires that "BUMPERS must protect all exterior corners of the BUMPER PERIMETER." and refers to a drawing that has bumpers on both sides of a corner with the padding extending all the way out (I'm sure this explanation is slightly confusing, I suggest you look at the diagram in the rules to see what I am referring to). It wouldn't take too much to make this legal, you'd just have to sacrifice a bit of your collection area on the front to make room for the 6" of bumper on each corner. And remember to leave 7" out of the back for the trailer hitch.
EDIT: I didn't notice that the bumpers extend past the corners. I think this is a question for the Q&A, as the rules are vague about whether protecting a corner requires bumper on both sides (as the diagram suggests), or just a bumper on the corner.
Unread 07-01-2009, 00:50
AdamHeard's Avatar
Lead Mentor
Yup, your post explains my internal debate precisely.
We will QnA it, which will be hard to describe via text.
I say it is legal, and should be legal per the rules and the intent of the rules.
If it isn't, then only wide robots will be able to pick up two balls wide.....
Unread 07-01-2009, 00:51
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
This looks legal to me. I see what your question is, but it still sounds legal, and within the intent of the rules. You should be fine, but Q&A can't hurt.
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 07-01-2009, 07:37
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Well you cant also forget about the big gap you have to leave for the trailer in the back of your robot
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 07-01-2009, 07:47
GaryVoshol's Avatar
Cogito ergo arbitro
I suspect this was drawn prior to reading Team Update 1. Where's your trailer hitch going?
I also question whether or not the soft portion of the bumper can extend beyond a corner if there's not a bumper on the adjacent side.
(since 2004)
Unread 07-01-2009, 11:57
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
I do not think this would be legal.
Originally Posted by R08
A. BUMPERS must be built in segments, with a minimum length of six inches, and a maximum length that does not exceed the maximum horizontal dimension of the ROBOT.
Looking at the way you have it set up in the picture, the bumpers on the long side extend past the robot.
Also, looking at the diagram on page ten of section 8, it looks like the bumpers need to have an adjacent corner as Gary suggested.
Edit: the rules say bumper sections have to be at least 6" long, does this mean 6" against the robot? At a joint, since the bumpers are 2.5" wide, can the adjacent bumper be mounted so that only 4" of it is braced against the robot?
Unread 07-01-2009, 12:22
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
My guess is no because i think bumpers need to be fully supported by frame this year.
Unread 07-01-2009, 12:31
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
There would have to be three sections. One covering the entire short side, including the corners, and two more covering the remainder of the long sides. Basically what that rule says is that no section can be longer then the length of the robot.
Does anyone else remember when TBA signatures actually worked?
Unread 07-01-2009, 13:31
AdamHeard's Avatar
Lead Mentor
As far as the current bumper rules, please read them entirely before replying.
Depending on the definition of corner, we are legal per the rules. The rules are ambiguous as to whether or not an adjacent bumper is required to extend the soft part out.
The gap for the trailer hitch wasn't drawn in because it wasn't really what I was asking for, the opposite to the open side will have it.
Unread 07-01-2009, 14:54
Bob Steele's Avatar
AKA: Bob Steele
I think you might run into an issue with saying that the front of your robot is protected by a bumper.
The rule says that the first thing that contacts the wall has to be a bumper.
A bumper in the definitions includes the mounting board.
Your design appears to be hitting the wall with just the cloth and noodle portion of the side bumper.
I can only surmise that the rule is there to protect the walls from needless damage from metal or other hard portions of the robot because of the sliding characteristics of the robots this year.
This is certainly a question that needs to be asked in Q and A and not on here to get a correct interpretation.
I know that if I were inspecting the robot ... and without any other indications from GDC or Q and A... I would not pass this bumper configuration.
Now is the time to ask... get it in writing and keep it with you for inspection.
good luck!!
Unread 07-01-2009, 16:58
AdamHeard's Avatar
Lead Mentor
We'll be submitting to QnA tonight, if this configuration is deemed illegal, I will be very upset.
It limits the width of ball intakes a very substantial amount, unnecessarily as well.
I like bumpers, I don't like overly restrictive bumper rules.
What is a legal bumper? lemon1324 Technical Discussion 10 26-01-2008 18:23
pic: Bumper and me lilac Extra Discussion 7 09-01-2008 16:22
pic: Team 1178 Robot - Starting Configuration Jake M Extra Discussion 1 01-03-2007 22:34
pic: A possible configuration of A-Rack-Nid DanDon Extra Discussion 2 08-02-2007 15:10
pic: 114 Bumper Art CraigHickman Extra Discussion 6 20-03-2006 20:35
